hitec servo?
RE: hitec servo?
Lots of people use them for steering.
I have one. I am not sure if I like it though, its hard to get centered properly and isnt quite powerful enough to run big tires. It is definetly more powerful than the stock
RE: hitec servo?
I have one for both Steering and Throttle, and I really like them. They're cheap, yet a lot more powerful than the stock servos. With the HS-645MG and Dual Disc Brakes, my Savage will frontflip 3-5 times when I tap the brake. Steering is a lot more responsive too.
RE: hitec servo?
ORIGINAL: casski22
did the hs-645mg is good for my savage?
hitec servo
metal gear
0.24sec/60deg of speed
7.7kg.cm of torque
hitec servo
metal gear
7.7kg.cm of torque
The 645mg is an excellent upgrade over the stock steeing servo. Even better for about $5-10 more, the 645's digital brother, the 5645mg! It has a bit more torque and is an excellent steeing servo to have for when you upgrade to a higher end radio that requires digital servos.
RE: hitec servo?
I run that same servo the 645mg I think it is awesome for the price. I bought mine when I was hurting for money and 8 gallons later it is still going
QC, CANADA
RE: hitec servo?
Like most people say, it'll do the job and is better than the stock but there are much better ones availlable. If your stock steering servo is still good use it for the throttle/brake, this way you get a 2 for 1 upgrade.
