HPI Monster Truck Forum Talk about HPI monster trucks here. The infamous Savage 21, SS, .25 or any other HPI MT. You can optionally discuss HPI in our general MT discussion forum if you prefer.
Reverse Module Install
Old 07-30-2007, 07:59 PM
BDFH
Default Reverse Module Install
I'm having trouble with my reverse module. I have it installed but can't get it to stay in either gear. I'm not using the hump pack battery, is this a must? It works some what but when I shift into reverse or forward then drive it always pops back into a neutral position, where I have no drive at all. I'm using a JR servo for the reverse, seams like it won't hold it in gear.
Old 07-30-2007, 08:27 PM
nothinbetr2do
Default RE: Reverse Module Install
try and fine tune the adjustments, try to get max throw in both directions
Old 07-30-2007, 11:45 PM
azzman
azzman's Avatar
Yea it sounds like its not moving the actuator far enough.
Old 07-31-2007, 05:00 AM
(X)
(X)'s Avatar
I heard that a 5 Cell Hump Pack is a MUST because regular AA's don't have the power
Old 07-31-2007, 08:06 AM
BCKoots
I don't think a hump pack is mandatory, you can use any servo. Torque is not an issue for switching in and out of reverse. I also believe you need to adjust your servo for max throw in both directions.
Old 07-31-2007, 12:51 PM
BDFH
Ok thanks I think I have it figured out.
Old 07-31-2007, 04:31 PM
azzman
azzman's Avatar
ORIGINAL: (X)
Sorry mate but that IS complete bollocks...
