HPI Monster Truck Forum Talk about HPI monster trucks here. The infamous Savage 21, SS, .25 or any other HPI MT. You can optionally discuss HPI in our general MT discussion forum if you prefer.
fuel line
Old 07-30-2007, 10:12 PM
xkev
Default fuel line
Does the lenght of the fuel have any effect on the engine?
thank
Old 07-31-2007, 06:38 AM
DaveG55
DaveG55's Avatar
Default RE: fuel line
Longer line can make the engine harder to prime because the fuel has farther to go.
Short fuel line, if it's wrapped around the heat can cause the fuel to preheat, which can cause problems.
Longer fuel line will give the truck longer run times when it flips in a wreck which gives you longer to right the truck.
Longer line can cause tuning issues if there is poor exhaust preasure to preasurize the tank - doesn't hapen too often though.
I usually run my fuel line about 1' or so long and coil any excess and zip tie it to the roll bar or something.
Old 07-31-2007, 06:53 AM
xrapidx
So...if you don't want your fuel getting hot...where should you run th line?
Old 07-31-2007, 08:24 AM
NitroDemon18
NitroDemon18's Avatar
ORIGINAL: xrapidx
Longer is usaully better. Just keep it away from hot parts like the cooling head, pipe, etc.
Old 07-31-2007, 09:16 AM
(X)
(X)'s Avatar
ORIGINAL: xrapidx
Well just wrap it round your roll bar or something, just make sure it isn't actualy touching the hot parts
