My Savage wont lift up anymore?...Help.. :(
ON, CANADA
I had a hard time keeping the front wheels on the ground, I actually have a video of doing a 2nd gear catwalk, But now for some reason it wont lift up...
I replaced : Spur, bell, shoes, re-packed diff's, new tires, etc...anything I thought of I tried but I cant help feel that I overlooked something.
If anyone has any ideas on how to make her lift again, it would be great..
thanks..
I attached a few pics of it after a total strip down and cleaning, I went mudding last weekend.. fun stuff..
thanks..
RE: My Savage wont lift up anymore?...Help.. :(
might i suggest putting some lightweight parts infront to make it easier? like from carbon fiber? maybe the spur gear or some gear is worn out. tht may cause the acceleration to be crap. try checking the gearbox or something. btw my savage only wheelies once in a while.
but i still think the front is 2 heavy take off the front diff to make it a RWD lol. then u can take the front gearbox and some dogbones off and it'll be lightweight infront
it'll also make it a RWD wich has a faster top speed and it might increase ur chanses of a wheelie. i'm not sure if it works lol. i don't know much yet. haven't tried it. i'm only 13 lol
Over and out: Savage_Crazy
btw i see tht u have aluminium upper arms. aluminium isn't as light as the stock material. did the wheelie stop after u put tht part on?
OH
Tuning. It will seem in tune, no wheelies, tune it better and it wheelies. wheelies dont always require going leaner either. mess with the tune
Is it possible the hex on the tires stripped.
I know how frustrating that can be. I had the same problem at one time. It was a combination of the clutch shoes, rear diff and the K 4.6 (.28)
I see you have a rear exhaust get rid of that pipe and put a normal one on and i gaurantee you will lift those wheels no problem especially with those purple springs if you really want to lift and get some low end buy the HPI ribbed pipe. The rear exhausts suck for low end,wheelies!! If you want some top end go for the HPI polished pipe even with the polished pipe you will still lift the front wheels as long as the rest of your drivetrain is in good shape and you know how to tune. There are many great pipes out there so pick and choose wisely those are just a few I have experienced on a stock savage. My LE Savage would shift all three gears on the back wheels with the S25 and the polished pipe with the black stiff springs. Now I have an Axial 28RR and can bounce the front end off the ground on a rolling start in second gear. Stiff clutch springs and aluminum shoes and a great tune are key to wheelies just make sure she lands on all fours!!! Giddy Up
As mentioned, tuning and the slipper nut are probably your problems assuming you installed the clutch shoes and springs right and that all the driveshaft set screws are tight.
Anybody who really knows Savages knows that the rear mounting pipes instantly cripple all thoughts of wheelie's!!! If it was the slipper or the clutch I think he would have stated the obvious like "the car revs but doesnt move" its the pipe trust me !!
AZ
Well if you knew savages the slipper can be just tight enough to make it move but when sudden torque is applied it will slip if not set rite.lol
AZ
ORIGINAL: ace007
I'd also say tuning... check your o-rings... my HSN o-ring went bad on my TM323... I replaced it... and INSTANT improvement in power.
ORIGINAL: RLMHPI
OK you guys are the pros step out of the way boys !!! I cant wait till this weiser person posts back with his results!!! Have any of you guys ran a rear mounting exhaust on your trucks???
OH
Nope, but that's because we run our trucks hard. my Savage hasn't seen a stock engine in at least a year and a half. No wheelie troubles with me, LOL. That and as often as my truck lands ass-first, i sure as crap don't wanna spend $70 on a rear-mounted pipe that'll get destroyed first run.
AZ
Also i as far as i know there is no performance gain from a rear exhaust its pretty much to keep the fuel residue off the right side and right rear tire by blowing it out the back.
ORIGINAL: ThunderbirdJunkie
MA
ORIGINAL: RLMHPI
ORIGINAL: RLMHPI
Very true you are right it use to pop wheelies maybe its not the pipe totally but I have seen first hand how much those rear exhausts restrict bottom end. My friend has the rear exhaust and the ribbed hpi pipe.With the rear pipe on its crayz loud and cant lift the front wheels at all. Switching to the ribbed pipe you can bounce the wheels up and down off the ground. Maybe there are other problems with this guys Savage its very hard to diagnose a problem 100% through a forum its just my opinion maybe I am wrong. No more comments for me in this thread i am getting beat up..lol... the guy who originally posted the thread is probably pulling wheelies with his savage as we speak laughing at us......lol.... maybe he removed the exhaust.. tightened the slipper.... put the clutch shoes on the right way......tightened his outdrives..... replaced his wheels with the stripped hexes with new ones there are so many different possibilities one thing i know is the rear exhausts are no good for Savages I personally dont like them I GIVE UP!!!
OH
ORIGINAL: RLMHPI
What are you rambling on about "we run our trucks hard" who was talking about a stock engine. I wasnt asking about the rear exhaust cause I was promoting it or I liked it. I too dont run a stock engine and have no wheelie troubles I too dont want to spend 70 dollars on the rear crap!! Man people on here can just go off on their own stick to the topic and read the posts!!!
I'd blame it on stock plastic clutch shoes, but then again, if you ask me, stock plastic Savage clutch shoes are the reason that Michael Moore is still alive, and he feasts on HPI using them in every Savage.
WI
Aluminum clutch shoes would provide a better engagment then plastic leading to better launches. It could be your engine is getting tired and old though as well. Hard to say. Another thing is fuel if your fuel has spent more then a few hours in the sun or outside in humidity chances are its loosing its nitro content.
