My Savage Wont Wheelie!!
OH
Just broke in my Axial .28 spec1
I leaned it out till my temps got to between 220-240
any more then that and i can notice a drop in performance but my savage wont wheelie.
I read a lot about all the low end the axial has so i got 46/20 gearing to try and tame it a bit
Is that gearing too tall for wheelies or should i start looking for problems somewhere else?
ON, CANADA
RE: My Savage Wont Wheelie!!
20/46
wow that thing must go like stink.once it get going.
spur divided by cb = gearing
46/20=2.3:1
so try a
18t cb
46/18=2.56:1
my lrp spec3 i got
49/17=2.88:1
and i can still lift big joe's and a total of 15lbs(custom rollcage/skid/etc) of truck no problem.
46/20=2.3:1
so try a
18t cb
46/18=2.56:1
my lrp spec3 i got
49/17=2.88:1
BC, CANADA
That's a 2.3:1 gear ratio. I would think that is pretty tall. With the k4.6 motor from HPI and stock gearing 47/17 (ratio 2.76:1) the truck wheelies just fine. You should try to be closer to 3:1. With low end grunt you shouldn't have to go that low.
Yep, your gear ratio is way too high. You will want at least a 15T/49T combo or a 16T/49T combo if you want wheelies on command. Also, your Axial might have a ways to go before being fully broken in and leand for performance. That too will give you some wheelies even on 20T/46T combo.
ON, CANADA
ORIGINAL: SAVAGEJIM
read up
jim know's nitro.
he's been here longer.
OH
cool thx guys i think i will try 46/16 i got the savagex slipper and my 46 spur is the only one thatll work
and it does go like stink lol! It does lift up a little too just no wheelies
i have the same problem and i have tried lots but still no joy "i miss my k 4.6" luv a wheelllllllllllllllllllllllllie
ORIGINAL: munro300
Im pullin wheelies with a 18/49 gear set up on my old axial .28 no problem, get rid of the 46 tooth spur.
ORIGINAL: gimp chump
By the way, can you post a sound with vid of you engine running? I want to hear what it sounds like at idle, while your are doing dead-stop full trigger pulls and some mid-RPM range sounds. I still think you Axial either might not be fully broken in and/or you have your needles still set too rich.
ORIGINAL: SAVAGEJIM
Tuning by sound is the PRO way to do it, no offense but temp guages are kind of for noobs. All you need to do is listen to the engine and you can get it tuned right. I have never owned a temp guage and dont plan to buy one, all of my engines have run spectacular without them. (Except for my first, TRX 2.5, two reasons for that. 1: Its a Traxxas engine[:'(] 2: I was a nub and it was my first engine) Learn to tune by sound, its much more usefull than any temp guage, unless you memorize the optimum operating temp and just set it from there....[8D]
ORIGINAL: SAVAGEJIM
ORIGINAL: gravediggerracing
My Axial 28 will easily wheelie with 17/47 and even taller 19/47 gearing. It even popped wheelies during break in.
ORIGINAL: SAVAGEJIM
so 17/47 is the best ? should i order some and get ready for my wheelies oh and i take it that my idea of 48/14 is not a good 1 and if not why not [8D]
18/47:
http://s166.photobucket.com/albums/u...inandWh.07.flv
ps Same engine, HPI pipe, Mugen alu clutch shoes, Chronic front extended TVP's..
OH
hey guys
well i lied my savage does wheelie with 46/20 gearing
i adjusted my 2 speed to shift later and i turned my low speed needle back to flush started it up and the thing just about jumped around like a frog i wouldnt call it wheelies on command but i almost fliped it once or twice
thats good enough for me
ORIGINAL: PatrickBW
20/46 still seems way overgeared.. Won't that just overstress your clutch??
hell find out when the shoes muchroom over weld on to each other and stop working
right i'am gonna order a 14/52 or a 17/47 but what would do but i'am thinking maybe i will go for a good top speed so whats the best combo for that without any problems like haveing to take a dremel to my engine plate
OH
[quote]ORIGINAL: MiamizFinest
ORIGINAL: PatrickBW
[/quot
Id be surprised if my shoes welded toghther i hope they dont but oh well if they do
I like my 20/46 combo so far wheelies very easy to cantrol but theyre still there and tons of top speed
wait till i add the new savage x 3 speed [>:]
