Good placement of fuel filter and fuel line(s)?
MB, CANADA
Hello again,
So all three hobby stores in town are saying my old tank is probably leaking and having the fuel come out of the bottom is the old way. So I spent a little bit on a new tank. The previous owner of my Savage had the lines running below, and directly behind the engine. Because the nipple on the tank is above now, I had to move it. I also heard it's best to try and keep some distance from the engine so it doesn't heat up. I took a few snap shots. Let me know what you all think. I'd like to hear your opinions.
ON, CANADA
RE: Good placement of fuel filter and fuel line(s)?
that look ok.it clear of anything moving.
was going to post a pic of mine.
you got me to check found my filter leaking. thanks
i run mine outback.
give's me a longer fuel line so if i flip it.i got some extra time to get to it.
i run mine outback.
MB, CANADA
Rex, do you find that gets in the way of the lid to the tank though? I considered that direction but I thought the tubes would bother me there.
MB, CANADA
ORIGINAL: ntloser
Doesn't the stock savage tank have a built in filter? I know the 125cc OFNA one does.
Racing Fuel Tank (160cc/No Primer)
Fits Savage. Rear fuel pick-up with internal filter and no primer
Is the internal filter good enough though?
WI
Its always a good idea to run a filter anyway im pretty sure almost all tanks now have a built in filter. As for the lines it doesnt really matter so long as they cant get caught in anything that spins. Changing lines may lead to retuning also so check engine temps for the first few minutes
MB, CANADA
ORIGINAL: Vigilante212
