14 mm TO 17mm
OH
14 mm TO 17mm
whats the easiest way to upgrade a savage 25 to 17mm hexes
can you just swap out the savage 25 14mm for the 17mm that come with the savage x or are there more parts required?
my 14mm are just about stripped out i read a post where someone said they glued the hexes to the rims
does that work?
thx for any info
does that work?
thx for any info
ON, CANADA
RE: 14 mm TO 17mm
ORIGINAL: []TEX[]
They are completely interchangable. No extra parts are required.
if your 25 has the left hand threads(counter-clockwise nut)on the left side.
then you'll need to change the axle stub to the same as the right side(clock-wise thread) to use the larger x(17mm) nuts.hpi # z680.
GA
RE: 14 mm TO 17mm
No they are not if you are talking about using the stock shafts as one side is left handed for the 14mm hex drive and the X are all right handed so the special nuts will not work for the 17mm hex. You will have to change the shafts on one side. This is the way I am going to go when I change to 17mm and much better then the stock 17mm like that come on the X.
http://www2.towerhobbies.com/cgi-bin...?&I=LXKZR3&P=Z
RE: 14 mm TO 17mm
Good point. I never had the 17mm hexes so I really do not know much abou them. I do know for sre that the Pro-Line 23mm hex adaptors are a direct fit though!
OH
RE: 14 mm TO 17mm
ORIGINAL: 46u
thats what i was gonna use as well but just swappin over is a lot cheaper
RE: 14 mm TO 17mm
