Beefier Steering turnbuckles...Literally
I wanted to replace my steel turnbuckles with 4x92mm Titanium ones from Lunsford. However, our LHS only offered 5x92 and will take a couple months before they replenish their items.
Due to my impatience, I purchased the 5x92mm and I somehow found a way to install it on my savage. Check my pics! I was able to found parts from a Hobao Truggy upper arm set and 6.8mm Kyosho rodends.
With the new turnbuckles, it is even larger than the dogbone itself!
Moderator
RE: Beefier Steering turnbuckles...Literally
Nice, I should do something like that. Its amazing how I manage to break turnbuckles.
Ive done things that have sheared my Baja 5Bs turnbuckles in half :/
QC, CANADA
Never broke one, not even bent one. All i ever got as a problem with them is the plastic loop getting loose and falling off easily. Nice find though.
ON, CANADA
ORIGINAL: -SomeGuy-
Nice find! But Ive also never broken one on my Savage. Only part that seems to break easily is the castor block and shock shaft once in a while. I'm planning to go CF turnbuckles from JDCarbon in time[8D]
