savage noob/tranny removal
FL
what is the simplest way to get the tranny out of this truck(savy.25),or is tearing it down completely from the rear bulk assy/engine plate the simplest way?also if i have to take the rear assy out of it along with the engine plate,should i drop in a freshly broken in wasp.28 or leave the new 4.1 in it?this truck has the 4 spider diffs,and i am dropping the 4.6 tranny in it..
My Feedback: (16)
CA
RE: savage noob/tranny removal
Do you mean that you are dropping a three speed tranny in it? I'd personally keep the 4.1 and use it till it's worn down then swap 'er out, but that's up to you.
The easiest way I found to take the tranny out is take the wheels off one side of the truck, remove the screws at the bottom of the innermost shocks on the same side that you took the wheels off of, remove the TVP, then flip it over and remove all the screws securing the tranny to the other TVP and to the engine plate. You might have to remove the engine as well; I don't remember if you do or not.
FL
i am dropping a two speed backin it ,i got it from nitronutzz on ebay,WIFE wouldnt let me spring for the 3 spd.and i was mistaken its not a 4.6 tranny its an x.i am really trying to find a comparison between the 4.1 and the wasp28,
ON, CANADA
ORIGINAL: megamaxx
your bumpin up to a .28.
if its like my jump from the 4.1 to the lrp spec3. your wife will be trying to smack that stupid grip off your face.
FL
i get that stupid grin everytime i fire one of these bad boys up.god i love the smell of nitro,but back to the subject at hand,i broke the wasp in on a FLM.21 conv t-maxx[sm=thumbs_down.gif]with 40 series wheels and that engine does not seem to like that set up,it just seems to be screaming,savage,SAVAGE!!!!
