Engine Winter Storage help
AB, CANADA
What is the best way to store an engine over the winter? I have a fairly new Axial .32 that i dont want to run during the winter. I am planning on using my old f4.1 instead. Any tips would be well appreciated!
RE: Engine Winter Storage help
2-3 drops of after run oil where the glow plug goes, and 2-3 in the carb, crank it a few times, and that's it, ready for the winter summer anything.
ON, CANADA
zip-lock bag it as well.
just an extra thought.
anyone thought about those little silica bags that come with tools or other metal parts for taking moisture out?
My Feedback: (8)
Make sure you run it dry the last run of the season...then load it up good with after run oil...then put it in a zip-loc bag...it'll keep that way as long as you want. (I've got model airplane engines that are 60+ years old and have been stored like that and would be good to go at any time)
Take the plug out and put some oil in through the plug hole and carb...about a teaspoon full...turn the engine over to get the oil worked into the nooks and crannies...the wrist pin is prone to rusting as well as the bearings and crank, so you need enough to slosh around and get under the piston.
When you want to run it again, flush it out well just before you want to run it, with fuel. (take the backplate off to make sure you get the oil rinsed out real good...)
Automatic transmission fluid makes a good after run oil (ARO ) and it's relatively cheap.
MI
WD-40 seems to work rather well to help flush out all of the old fuel and moisture. It even helps if you have an engine with an internal 1-way bearing like my 4.6 that doesn't want to catch during start up.
ORIGINAL: pythonfan
WI
ORIGINAL: smalltownsavage
wd-40 is a water repellant/oil. you should use a degreaser on a oneway bearing thats slipping.
ORIGINAL: electricnitro
One other thing no one has mentioned is to leave the piston at bottom dead center of the stroke. This will keep the pinch intact.
NC
ORIGINAL: gravediggerracing
You should be doing this all the time as well.
