Hump pack
Hump pack
So what would be a very good hump pack for a savage tht lasts long and is very reliable?
also is there a hump pack for the transmitter?
Thank u!
Thank u!
RE: Hump pack
ORIGINAL: Savage_Crazy
Thank u!
Thank u!
If you want rechargeable for your transmitter...just buy (8) Energizer 2500mAh AA batteries and be done with it. I've done this as well and love it.
ON, CANADA
RE: Hump pack
this is the set i bought.comes with the overnight charger as well.
been about 3 months now and there still working great.
gotta buy somemore now that i got 3 trucks.
http://cgi.ebay.com/2-6v-1100-BATTER...QQcmdZViewItem
they have 3 different sets.
1100-1300 mah's
my 1100 mah last a longtime.
they usally outlast the truck.
1100-1300 mah's
RE: Hump pack
ok...i'm gonna need something the lasts for atlest a year....about 1500Mah and a good charger (1hour charger or so)
don't care how much they cost
NC
RE: Hump pack
ORIGINAL: mazdab2600
1100-1300 mah's
1100-1300 mah's
I've not seen any 5cell packs that are over the 1500 rating. Maybe I've not looked hard enough.
RE: Hump pack
I have an LRP 1100mah pack and that works good, i got this charger that charges the controller ( little charger fits in the back of my JR XS3 with its rechargeables) and this charger charges the hump pack as well, and can do both at the same time.
RE: Hump pack
ok...so how long would [link=http://www2.towerhobbies.com/cgi-bin/wti0001p?&W=001242108&I=OFNP1214&P=K]This[/link] charge [link=http://www2.towerhobbies.com/cgi-bin/wti0001p?&W=001242108&I=HPIM2012&P=K]This[/link]?
How long does a 1200 mAh last ( in hours)
and how long does it last till it's totally unuseable (in years)
Is the Hpi hump pack even a good choice?
Also...here is the [link=http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXNMD7&P=ML]More than 1500mAh pack[/link] that u thought didn't exist
GA
RE: Hump pack
10 hours give-or-take from flat to full charge
impossable to put a number to - but it should last you a good day of driving if not two
impossable to put a number to - I've got packs that are 4 y/o and still going strong but lots of different things can kill a battery
no experence with it but why not? most of hpi's stuff is good
don't be so smug - if you knew everything there was available/to know you wouldn't be asking these questions
RE: Hump pack
I made a pack from 5 fullsize 1800 mah AA:s. I fits nice in the box on my X after some modifications to the lid. I only made it to try it out, but it works so good that a new one from some 2700 mah ones will be made. I maybe will use the new generation of nimh-cells due to their better function in cold temperatures. It´s cold here in the winter.
I have a "brand x" 1100 mah hump pack as secondary unit. Works OK.
RE: Hump pack
could i make my own transmitter hump pack?
if i can , then with what? and how?
also it should have a known design so i could buy a charger for it
GA
RE: Hump pack
The easiest thing to dp for the tx is to just buy 8 AA rechargable batteries and install them into the existing battery holder. You can find them in 2500mah size for not a lot of money (+/- $15 in the states). That will give you a nominal voltage of 9.6v which will work fine. I have done this with all my radios and it works great. If you want the voltage to be higher (some people do) then you can often mod the existing battery holder to accept 9 batteries, mwhich brings you to 10.8v. Or you could buy 10, 2/3 AA batteries (for 12v) and solder them togeather and that will usually fit where the stock battery holder fits.
RE: Hump pack
could i make a hump pack out of the batteries?
all the batteries connected with a wire in the right way and the some kind of wire comes out of the transmitter battery holder and goes into some hole or something?
or would it be tooooo complicated?
if i'd buy rechargeable batteries then i would also need good chargers
those might cost alot
if i'd have a hump pack i could only get 1 loader
RE: Hump pack
cool
but now i would like kind of pack for the transmitter
does such thing exist?
cool
http://www.rcuniverse.com/forum/m_63...tm.htm#6324842
Also the HPI Humpback 1200mah is excellect choice!!
CA
RE: Hump pack
i have the same 2 humpacks of 1100 MAH that you can find here www.cheapbatterypacks.com
for the charger i have dynamite and it takes less than 15 min to fully charge 1 battery. I love it.
hell, if you wanna go nuts, get the 10,000 Mah 6V one, and it last you more than 2 full gallons of fuel if you do it non stop. LOL
But you cant mount the battery inside the battery box though[&:]
