LST Shock Kit
Location: Bakersfield CA now watford UK, UNITED KINGDOM
LST Shock Kit
Ok I want to put this kit on my Savage x ss but I heard I need old savage arms would that be all arms front and back or just the bottom arms thanks.
RE: LST Shock Kit
Wait. Wont LST conversion and the X conversion work on a stock Savage SS?
I hope so cause I got both of the below items thinking they would.
http://www.innovative-rc.com/product...products_id=48
http://www.innovative-rc.com/product...roducts_id=176
RE: LST Shock Kit
ORIGINAL: xrapidx
So if I had a Savage X 4.1, what all would I need off that site?
RE: LST Shock Kit
Thanks... are they difficult to mount? Or is it fairly straight forward? Will any serious body modifications need to be done to the Savage X as it is now?
RE: LST Shock Kit
I didnt really need to change anything on mine, the only thing was that i was running the sav x bulkheads and shock towers and the kit i had was for the standard shock towers, i drilled out the mounts to suit the towers
RE: LST Shock Kit
ORIGINAL: ntloser
Err wait... I mean to say
Wont the LST conversion and the X conversion work on a stock Savage X SS?
QC, CANADA
RE: LST Shock Kit
ORIGINAL: ntloser
ORIGINAL: ntloser
Even then you could just have gotten this http://www.innovative-rc.com/product...roducts_id=130
You didnt need to spend the extra on the conversion kit.
RE: LST Shock Kit
ORIGINAL: -SomeGuy-
ORIGINAL: ntloser
ORIGINAL: ntloser
I saw that but it said "NON X Arms" I assumed I had the x arms since it is an X SS kit.
RE: LST Shock Kit
ORIGINAL: -SomeGuy-
"NON X Arms" Means you need the savage 25 arms. The X arms dont have the lower mounting holes.
Is this right?
Savage X needs these;
Savage X with NON X arms needs this;
QC, CANADA
RE: LST Shock Kit
No matter what savage you have you NEED savage 25 lower arms to be able to mount LST shocks, no matter who you get the mounting kit from. No one has come up with a way to mount them on X lower arms, thats why they specify "non X arms"
If you have the older model then ALL you need is this:
If you have the newer X model then ALL you need is this:
What you bought is the kit for the older model. The upgrade kit is for someone who had the kit on an older savage and wants to transfer it to an X without having to buy a whole new kit.
RE: LST Shock Kit
Same thing as the 25's need. The regular mounting kit and assuming you have the original arms, all you need is the shocks. Ill be experimenting with them when I get mine, but am having paypal problems right now.[:@]
QC, CANADA
RE: LST Shock Kit
If you really want something made in the USA then you could go for this kit: http://www.neweramodels.com/item.cgi...=&part_id=3184
QC, CANADA
