4 Stroke Savage
#53
RE: 4 Stroke Savage
Hey that looks nice! Still kinda stuck on this Saito engine. May do the FUJI after the Saito http://www.youtube.com/watch?v=Nig3k...eature=related . It will be a while though maybe spring before I get this thing a flying...hehe. I have to reseaarch the FUJI[8D]
#54
TN
RE: 4 Stroke Savage
This is a very interesting subject, me being an airplane guy also, i love four strokes. but this is what i've been looking at; http://centralhobbies.com/Engines/ys/YS63s.html there are bigger motors that they have, but the rpms on this motor would be easier to gear for,. imo
#55
TN
RE: 4 Stroke Savage
But if you really want power this would be the sh **. http://centralhobbies.com/Engines/ys/ysengines.htm. all of ys motors are fuel injected, supercharged...........
#56
TN
RE: 4 Stroke Savage
http://centralhobbies.com/Engines/ys...ines.htm#DZ170, sorry the other link broke.
#57
RE: 4 Stroke Savage
Man that YS Engines really looks nice, can't find any demensions or hp rating on it though, the Saito FA-125 will be a very tight fit but do-able. Now if the FZ110S Engine has smaller demensions but still puts out the same hp as the 125 it might do the trick.
#58
TN
RE: 4 Stroke Savage
heres a discussion on ys motors.http://www.rcuniverse.com/forum/m_2286099/tm.htm
#59
TN
RE: 4 Stroke Savage
#62
RE: 4 Stroke Savage
ORIGINAL: raptornut
I cant wait to see your finished project, It should be one bad ***** savage.
#63
RE: 4 Stroke Savage
Ok hey guy's I was trying to keep things on the dl because I haven't gotten very far. I haven't made that trip to Baltimore to have the engine mount made, hopefully that will be soon. PM'd someone a pix yesterday of the latest, out of all fairness I think I should do the same here. MAN! I can't wait until spring! Much thought has gone into this thingy so let me know what you think. Here ya go. Oh the engine is just setting in there no mount.
#66
RE: 4 Stroke Savage
thanks Art91 and Vigilante212! it's gona have mega torque hope the tranny and diffs can handle it, gearing for speed. Since you said it, it does looks kinda of under size in these pix but it's not. Nearly twice the size of Axial .32 in everyway. Thanks again for the good words buds!
#69
RE: 4 Stroke Savage
Hi .. i write from italy and olso i have this project fot to put a engine 4 stroke in my savage... i have put one SAITO 82 but the big problem is the starting!!! i think that the flywell is too small and don't start the engine... sorry for my english , can you help me for this problem?
Ops.. sorry.. my name is Claudio
#70
RE: 4 Stroke Savage
Hey there looks like a great project! This is tricky because of the flywheel access in the Savage, I've seen a vid on youtube with a 4-stoke powered Savage (modified airplane engine like the 82) but I can't find it.
Anyways, it looks like you are using a boat flywheel? How did you manage to mount the clutch bell onto the crankshaft? Thanks bud.
#71
RE: 4 Stroke Savage
Wow Claudio that look great, you have gotten further then I have. For the flywheel you don't want it to be too heavy or too large, because that will hamper acceleration. Try to find one about the same weight as a prop meant for your engine size. Now for starting from what I see from your setup something like this might work. Find the right combination (shaft size). Remove the cup and install the wheel, then spin it agains your flywheel, if it's spinning in the wrong direction reverse leads to the battery. That's the way I'd do it given your setup, I hope that helps. Good luck!
http://www3.towerhobbies.com/cgi-bin...rter&search=Go
http://www3.towerhobbies.com/cgi-bin...heel&search=Go
#74
RE: 4 Stroke Savage
i am a fourstoke guy too but would never put one in my savage. all my dirtbikes are fourstrokes but are very advanced. I think you will be very disappointed when you get finished. they do not produce the power of a smilar 2 stroke even at double the displacement. i seen a tmaxx with a four stoke and it was so cool , it had the coolest looking exhaust sounded awesome and was very slow, tons of torque but no snap. would barely spin the tires on dirt. check out this video of a fourstroke savage. correct me if im wrong but i think my f4.6 would be right beside this thing?
http://www.youtube.com/watch?v=ioGFZEAa90A
#75
RE: 4 Stroke Savage
Ya I saw that video before, and that's a dual 4 stroke. Every Dual anything either 2 stroke or 4 stroke had dismal performance I could be wrong, but lighten it up (one engine) also a light flywheel geared right you should be fine.
