HPI Monster Truck Forum Talk about HPI monster trucks here. The infamous Savage 21, SS, .25 or any other HPI MT. You can optionally discuss HPI in our general MT discussion forum if you prefer.
Anyone polish stock TVP's?
Reply
Old 12-25-2007, 09:21 AM
Hordsak
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Anyone polish stock TVP's?
I've tried searching, but I can't find anything. I'd like to know if anyone here has removed the stock paint, and polished their stock TVP's? If so, how did you do it, because I think they would look pretty good polished. Thanks.
Hordsak is offline
Old 12-25-2007, 10:26 AM
Parputt537
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Anyone polish stock TVP's?
I have seen trucks with it done and they look sweet. Not sure how they did it, but I would imagine you could use a dremel to get the paint off then some Mothers to polish them up nice and shiny.
Parputt537 is offline
Old 12-25-2007, 10:34 AM
Rudeboy
Rudeboy's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Why not just use paint stripper? Or even just some decent paint thinner is likely to strip that stuff right off.
And then it just a matter of elbow grease and polishing compound.
Rudeboy is offline
Old 12-25-2007, 11:06 AM
Hordsak
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Yeah, I've polished aluminum rims before. But before I could polish them, I had to remove the clear coat with some industrial airline paint stripper, I just don't know if that would be the easiest way. I have a buffing wheel and some aluminum polish, but the paint is the hard part. There must be an easy way. I suppose I could just sand it off with really fine sand paper, then wet sand it, then polish it. I'm just looking for the fastest way.
Hordsak is offline
Old 12-25-2007, 11:29 AM
SpikeX
SpikeX's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
TVPs are anodized, so you won't be able to grind it down with a Dremel or paint thinner. You have to dip the TVPs into a special acid to remove the anodizing properly.
SpikeX is offline
Old 12-25-2007, 12:05 PM
m_weinerich
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
"special acid" aka oven cleaner. Easy Off should do the trick.
m_weinerich is offline
Old 12-25-2007, 02:38 PM
-SomeGuy-
-SomeGuy-'s Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Caustic soda work best to remove anodizing, oven cleaner is easier to get though. Work in a well ventilated area, that stuff is toxic. I've heard of mothers mag but i use a polishing wheel with some polishing compounds. The dremel works ok but being so small its a real pain. A polishing wheel makes quick work of it.
-SomeGuy- is offline
Old 12-27-2007, 11:28 PM
Dman250
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Get some drainO kitchen crystals....just put a few cups of water in a pan and about 3-5 spoons full of the crystals and it takes a minute or two...just pull out and you can actualy rub the anodized stuff off with your finger...but it works better with a wire brush....after all that just sand with 600 grit wet,then 800, 1500, 2000 and metal cuting compound for a really nice finish....remember always wet do it in the sink or tub....
Dman250 is offline
Old 12-27-2007, 11:44 PM
nantucket
nantucket's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Or you can go to your local auto parts store and pick up some [link=http://www.greased-lightning.com/Products/Products.aspx?ProductId=6&type=auto]Greased Lightning[/link] cleaner. Thats what I used to remove all of that butt ugly purple anodizing off of my Savage, it works great and is cheap too![8D]
Just keep an eye on the parts while your using it... Oh and wear gloves too!
nantucket is offline
Reply
Display Modes
