If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Results 1 to 12 of 12
  1. #1
    Join Date
    Dec 2007
    yakima, WA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    roto start mach 427????
    If anyone has installed a mach 427 in there savage which roto start did you use??
  2. #2
    DaveG55's Avatar
    Join Date
    Jan 2005
    Stockbridge, GA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: roto start mach 427????
    Not the 427 but the Mach.26 - basically the same engines
    I installed it in my Savage and just used the HPI roto-start backplate. All I had to do was (carefully) drill four new mounting holes. I then used an extra mounting screw to tap threads into the aluminum. It's worked great for over 2 years now.
    Also, if I remember correctly, the XTM 427 backplate will fit w/o any modifications.
    Any technology, sufficiently advanced, will appear as magic
  3. #3
    Join Date
    Sep 2005
    Irgendwo, GERMANY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Supposedly, if you have the Spin-start unit from the Muggy, you can just use the original Losi spin-start.. Before it didn't work cuz the wand from the LST was too short.. The Muggy spin-start has a longer wand.. Defo the easiest way I think..
    The other way is to get the backplate from the XTM 24.7 to use with an HPI rotostart.
    Those are your choices basically...
    Nitro > stamp collecting, watching grass grow, cleaning room, etc.. > electric.
  4. #4
    Join Date
    Jun 2006
    , MI
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I have a sportwerks .26 same motor and I just use a drill. The losi spin start won't work but a drill works just fine with the spin start back plate.
    Savage X, sportwerks .26, HPI tuned Pipe, DD brakes. and also Lst2
  5. #5
    Join Date
    Sep 2005
    Irgendwo, GERMANY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    The Losi spin-start will work with a Mach because the Machs come with Losi spin-start backplates... But not the SW26..
    On a sidenote, I couldn't believe how cheap the SW26 V2 is at amain.. For $130 IMHO it's the best engine you can put in a Sav.. (or the Mach - same engines..)
  6. #6
    Join Date
    Jun 2006
    , MI
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I wasn't able to use the spin start because the rear bumper gets in the way and the starter shaft won't reach. Thats why I had to just use the drill. Maybe my bumper was out of alignment or something.
  7. #7
    Join Date
    Jul 2006
    redlands, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I did this on my mach 427. All you have to do is buy a xtm 24.7 back plate and one way bearing. And everything will bolt right up And works perfect.
  8. #8
    Join Date
    Mar 2006
    hayward, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Regarding the SW26 v2, did any of you guys change the internal OWB before you installed the rotostart? I have an OWB replacement for the stock F4.1 that would eliminate the need for the OWB altogether, but only if the drive shaft of the SW26 was more like that of the stock F4.1 that has the spring loaded PIN
  9. #9
    ThunderbirdJunkie's Avatar
    Join Date
    Jul 2004
    Norwood, OH
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I don't know if they've changed the XTM 247 OWBs or not, but the pin for the OWB on the crank of my M427 was too big for the XTM 247's OWB, so I swapped it out for a Mach 26 crank.
    can anybody post pics of their newer-than-mine Mach 427's crank?
    \"Some people can mess up an anvil with a rubber hammer\" -46u
    If you don\'\'t allow yourself to fail, you\'\'ll never allow yourself to succeed-ThunderbirdJunkie
  10. #10
    Join Date
    Mar 2006
    hayward, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    For my fix to remove the OWB from inside the engine block to completely outside, I'd need a F4.1 crank shaft, exacty like this one that has a hollow shaft for the pin to engage the rotostart starting shaft.
    My SWK 26 crank shaft looks very similar if not identical to this, which has the fixed pin that engages the inside OWB
    How compatible are the crank shafts between manufacturers and models?
  11. #11
    Join Date
    Aug 2007
    tuckerton, NJ
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I just did this today. I used a Tiger Drive adapter plate to mount the Savage Roto start system on. The Losi 427 Roto Start was blocked by the chassis/bulk head support. So I could have drilled new holes threw the back plate of the engine but did not want to. But all in all the adapter work great and there is lots of room for the wond and it was worth the $30.00 bucks to make it work the right way.
    Attached Thumbnails Attached Thumbnails Click image for larger version.
ID:	1071452   Click image for larger version.
  12. #12
    Join Date
    Jul 2004
    Norwood, OH
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
