30% NITRO?????
My Feedback: (13)
RE: 30% NITRO?????
yes u just need a little adjustment on settings on other engines.some guys add those o-ring for the engine ..i didnt do that on mine but it was the best thing i did on my engines..
MB, CANADA
RE: 30% NITRO?????
ORIGINAL: badboy2
RE: 30% NITRO?????
You don't need to jack with the head shims on a big block engine to run 30% because they are designed to run 30%. Simply fill the tank with 30% and slightly richen up the HSN and away you go. For best performance you should drop down to a med-cold or cold plug if you aren't already using one.
OH
RE: 30% NITRO?????
ORIGINAL: gravediggerracing
I was running an 8 now using an O'Donnell 100.
I have no idea what that converts to...but it sure does fire up an run alot better.
Force .32
CS
Banned
CA
RE: 30% NITRO?????
I always run a cooler plug when I run 30%. Right now I'm running cold plugs with 30% Platinum.
RE: 30% NITRO?????
ORIGINAL: burnchassis3
You say to drop down a glow plug ,meaning?
Force .32
CS
Force .32
CS
RE: 30% NITRO?????
ORIGINAL: nitro.rc.racer
why run cooler when you richen the car and not lean it
RE: 30% NITRO?????
ORIGINAL: bmwnla
not to hijack your thread......but my friend runs 30% with a hot plug in his truggy....is this a bad idea? What are the benefits
