Pipe suggestion for Sure Fire .32
Found a great deal on a Sure Fire .32 that I couldn't pass on.
Question is...what's a good muffler selection for this engine? The engine has monstrous bottom-end and great mid-range as well...think a top-end muffler would do?
BTW, my budget doesn't account for a $110 Buku muffler.
RE: Pipe suggestion for Sure Fire .32
Well I scored that SureFire 32R for $150 and will be getting it within the next few days.
I'm going to try it out with the stock HPI polished pipe first...and then with the Tsais header - Dynamite 053 pipe setup I have on my X SS.
We shall see what the difference is between those (2).
KS
Here's a new one if you need a spare! [link=http://cgi.ebay.com/Axial-32-Spec-1s-8-Port-Truck-Buggy-Engine-Grey_W0QQitemZ190205374174QQihZ009QQcategoryZ44028 QQssPageNameZWDVWQQrdZ1QQcmdZViewItem]32[/link]
ORIGINAL: BudBud
I prefer a high-winder...so I'm thinking of going with something smaller when my Axial .28 finally croaks.
KS
I think the Sunfire and the Axial 32 are the same engines, just lke the Axial 28 and the Hpi 4.6 are the same. I hope yours serves you as good as my Axial has me. I have two Axial 32 engines, the first one started easy, made great power at any rpm and has been trouble free, several gallons now and still doing a great job.... The second one was blessed with a badly leaking front bearing and could not be tuned. I replaced the bearing, but have not put it back in a truck yet. I have been too busy working on the Picco 28s. BB
Well the SureFire 32 and Axial 32 are the same basic engine inside of the same crankcase. The new SureFire 32R has a totally different piston/sleeve with additional port-work done. The original SureFire and Axial have nearly identical dyno plots with the SureFire making torque a bit earlier and holding out a bit longer.
As a side note...I just paid Rick Brake for the mods on the SureFire 32R. Man, I can't *WAIT* to see how that engine is gonna run! woo hoo [sm=what_smile.gif]
