Nitro Rush Evo problem
I know this model is a bit old...but I was wondering if anyone else had the same problem I am having. I bought the "upgraded" HD Disk Hub Anodized, and the o-rings they give you somehow let the pins slip out. I fabricated a new pin, but it's not exactly the same diameter, so it lets the slipper clutch slip too much and basically now I'm down. Anyone have a solution?
RE: Nitro Rush Evo problem
put shrink wrap around it to keep it in place, it should work, although i am not sure exactly what your talking about (as I don't have a nitro rush) but if you can put shrink wrap on it, give it a try
