takes off slow
takes off slow
hi guys, when my X 4.6 stop, i go for full throttle and the truck takes off slow and only the power comes around 2-3 seconds later. last time i use to do wheelies when i go for full throttle. can any one helps.. thanks..
LA
RE: takes off slow
Probably your tune. You need to tune when the weather changes. Sounds like the LSN is too rich. How does it perform at WOT. If it is sluggish at WOT I would try leaning the HSN first. If your WOT performance is good I would start leaning the LSN until it responds.
If your tune is good then check your slipper.
Great Tuning Guide: http://www.nitroreview.com/hintstips...ngTechTips.pdf
