neon green its bright.
MT
RE: neon green its bright.
Wait.. wait.. Cant see.. Need sun glasses..lol Looks good tho. Good body to see how far you can go before losing it.. Should be albe to see it for a half mile..lol
KS
I have been considering one of those M-37 or Power Wagon bodies. I wanted to OD the outside instead of the inside, so it would have that flat color instead of shiney OD green. Is the body pretty substantial? BB
ON, CANADA
BB
the bodies are .060 .better than hpi's
ax4000-war wagon
ax4004-b-17 betty
t9dragon
the windows are painted black. so it looks like tint.
i'll post pics of the bodies once painted and fitted.no hints on the colours.
ax4000-war wagon
ax4004-b-17 betty
t9dragon
KS
ORIGINAL: mazdab2600
BB
ax4000-war wagon
ax4004-b-17 betty
t9dragon
BB
ax4000-war wagon
ax4004-b-17 betty
t9dragon
ON, CANADA
sorry BB.
pearl purple.to bad the camera doesn't capture the full effect. looks awsome.
i'll be cutting out the windows on this one so i didn't mask them.
The way you cut out the piece for the cooling head, and pullstart / fueltank has finger annihilation written all over it. I have a good feeling you'll be reaming that whole section out after the first few gashes.
it's pre cut from axial. i'll be cutting/fitting tomorrow.
ON, CANADA
oh.
yes your right it needs more trimming.
took it out last night and had to remove the body to start it. then on warm up i blew the rear diff.
got new one's with the bodies.
How did you blow the diff? Ring pinion? Or the diff itself? Bearing on the diff? Just curious. My diffs seem to take a pretty hard beating.. I've only broken one pinion gear so far, and that was after many gallons of very hard bashing.
