savage 25 servo problem
AZ
ok so im haveing a problem with the throttle servo everytime i turn the reciver and controller on it goes full throttle . should i get a new servo ? aqnd if so what brand should i get?
KS
RE: savage 25 servo problem
There is a ton of great servos out there, it is like trying to tell you what kind of ice cream to eat. Everybody has a favorite. The new Hpi steering servo out of the XL trucks is pretty good for what they bring on Ebay. Bud
Check your throttle trim before replacing the servo.
If you want to stay with HPI servos, I highly recommend the SF-5 servo....over 300 oz.in of torque, metal gears and fast response time. Ebay is full of them for cheap.
does it move if you apply the brakes? if it does couldnt you take off the servo horn, while the truck and controller are on, and center the horn to neutral position? maybe you dont have the horn in the correct spot.
