Ever break one of these?
UT
I broke the rear center drive shaft today. Not sure how I I was not bashing that hard hehehe. Picked up a new one from LHS on the way home. Any suggestions on a easy way to replace it?
KS
RE: Ever break one of these?
I usually use the fuel tank side, remove the two side engine mount plate screws, the end plate screw behind the shocks and the lower side skid plate screw. Normally you can flex the side plate enough to get past the locking nub on the shock tower. Just twist the opposing plate, using the control arm on the fuel tank side, far enough to slide the shaft in. If you are not comfortable doing the plate flexing, reomove the screw behind the shock tower and the side screw for the lower skid plate. Now you should be able to flex the plates just enough to remove the rear differential, shock tower, and suspension from the plates. Put the shaft inplace and the puzzle becomes getting everything aligned at once going back together. You need to get both nubs and the shaft in place at the same time...... Hope you find the information helpful.... Glen
UT
Thanks Glen. I will try to fix tomorrow morning. Going to go and run it again tomorrow since still no snow at the end of November. Kinda strange for Salt Lake City. Its usually a lot colder by this time of year.
My Feedback: (10)
IL
wow, out of all my bones, the center ones are still nearly mint! The only issue I have with the center is the cups get warped...[X(]
Snow...up to 6 inches by Monday; I'm glad I already did a pre-run in the cold weather and my X4.6 is ready to go! Water-proof steering servo, greased the throttle/brake servo, 16t CB, and Pro-Line paddle tires should equal to a fun time! [>:]
UT
The truck only has 1 1/2 gal thru it, I would hope the drive train would last longer than that before a rebuild is necessary.
My Feedback: (10)
IL
ORIGINAL: 574kman
excesive slop in the driveline can cause dog bones to snap replacing all bones and cups and out drives with the heavy duty ss parts will help
ORIGINAL: tiemac
UT
ORIGINAL: BudBud
