Motor Tuning Help
Motor Tuning Help
Got my lrp running some what like it should but have a new problem. I just have the HSN above stock settings [:-] that cant be rite and my idle needle is about 2 turns in. It is running good but when i try to lean it out it bogs?
ON, CANADA
RE: Motor Tuning Help
start back at stock settings.
bogging could be to lean on the hsn/lsn.with 2 turns in on the idle it should be screaming with stock settings.so turn the idle down as well.
http://aedownloads.com/downloads/man...28R_manual.pdf
Finally got to run the truck again still having problems. Maybe im just messing up some were but this thing is weird truck starts up first pull and will sit there and idle fine. I got to the point were it does not bog any more at full throttle but the only way to do it is if i turn in the idle speed needle (one on carb slide thing) almost half way all the way in. I cant do anything with the high speed needle or it will bog. One thing that could be my problem is that the coil in the glow plug is little out of wack but still glows red could that be the problem?
