Savage XL Mods?
MN
Savage XL Mods?
Just bought an XL, in the process of breaking it in.... What mods should i do to this thing.... Money isn't an issue.... I already upgraded radio to Spektrum DX3S, HPI Big Bore Shocks, Fioroni Slider Clutch, and changed out the steering servo to a 333 in/oz Hitec Servo, so whats next.... Maybe engine, arms? You tell me what you would do....
RE: Savage XL Mods?
If Money isn't an issue and you are looking for some real performance upgrades...
Send me 1600 dollars via Pay Pal, and I will have your truck blessed by a little know RC Rabbi here in Newfoundland....his unorthodox techniques have been proven to get better MPG and and a generally faster rig. Although his work is not guaranteed...with a moneyback policy ....I have sent him thousands of dollars to make me the person I am today.regret free
Stephen.
Sorry....I don't know where this came from....one of those days....I can never really resist the "Money isn't an issue" comment.
Sounds like you are on the right track.....from what I've learned....just keep at it till that 5.9 eventually blows up and then upgrade the motor
If you are happy with the trucks performance...then there is no need to do anything.....if there is an area that is lacking...then thet area needs work/mods.....I take this advice from working on VW's....where power is always needed ...but the handling is nailed to a tree.
sounds like you have no problems steering....with that 333 oz servo!!!
Stephen.
KS
RE: Savage XL Mods?
I would put exhaust on it, best bang for the bucks and then run it like I stole it! We all treat them different and have different styles of driving, until you start breaking something, life is good, even better when you fix it. [8D] The local RC Rabbi works much cheaper here in Kansas..... Glen
MN
RE: Savage XL Mods?
LOL.... I put that in there cuz I wanted to know what the best mods were.... I don't want to spend money foolishly but if there were a 400 dollar engine that you recommended I would probably go buy it... that's what I meant.... As far as a pipe which do you recommend?
KS
RE: Savage XL Mods?
If you are willing to work with it, a Picco pull start 28 is the biggest bang for the bucks. I really want to try one of the new Nosrram, SH, or LRP 30s... which for somebody new to nitro, is probably the best buy. The Piccos can be tough to get broken in, although the later ones do not seem to have the issues.
On the pipe, I like the 086 and if you put it on your XL, when that 5.9 goes south or you want more power, you already have the best of the Picco exhaust. Running, I cannot tell any difference between the Dynamite and Ofna 086 pipes. Dynamite makes a hard coated pipe that is easy to clean, but lacks the flashy looks of Ofna's polished 086. Glen
RE: Savage XL Mods?
a must for the xl is aluminum c-hub and uprights as the xl plastic ones are not strong enough
then get hellfire front upper arms ( it must be the front as the rear ones have longer turnbuckle )
the hellfire arms are a direct replacement for the thin and weak tierods that are standard on the xl
here is a picture that shows how much beefier the new tierods are
My Feedback: (10)
IL
RE: Savage XL Mods?
How the hell do you guys break the c-hubs? I've had my truck run into a dumpster at about 3/4 speed and nothing happened to it, as well as many cartwheels on solid ground with no damage. IF/when something were to break, then I would rather buy the cheap priced plastic stuff instead of the expensive aluminum stuff. .02
Get yourself a modded Picco along with some different gearing and you should be well on your way. Put some real oil in your differentials and shocks as well.
RE: Savage XL Mods?
this is the second truck these aluminums are in and they have seen allot of bashing
yet there is no wear or anything out of shape. i have broken allot of lower arms while using these and no damage to them at all
and no the aluminum c hub and upright are not the reason for arms breaking. dumpsters and curbs are. plus a lightpost a sign post a huge boulder etc etc
MN
RE: Savage XL Mods?
Where do I get these hubs and uprights? Who makes them? I broke my upright by landing on the rear tire from a big drop.... Engine, u say get a modded picco, ok which modder do i go with?
TX
RE: Savage XL Mods?
ORIGINAL: Modsledd
