Carb for Sts .30?
BC, CANADA
Carb for Sts .30?
Hey guys I havent been on here for a long as time.. but apart from that went to run my Savage-T and i my carb on my sts.30 is done any suggestions on a good replacement carb other then the sts one since i cant seam to find one
CA
RE: Carb for Sts .30?
The Axial carb also worked very well on one of my STS's. Only thing with the Axial carb is the low speed needle seat screw, it can move on you while engine is running, so just put a covering of silicone over the screw and the silicone will bond to both the screw top and the carb case, there-by providing some locking to the screw. Easy to revove is you want to adjust or remove the screw.
Also RB carbs do a good job, but they are way more expensive than the Axial.
Dennis
Dennis
BC, CANADA
I have the rb mod sts i bought the dam thing so long ago hasent even seen a half gallon then my buddy went and broke the carb w/e ill take a look into the rb carbs money not a thing anymore in the hobbie or for my truck lol thanks for the ideas guys
