Xl disaster continues
Blowing up engines? Your not doing something right.
CS
Couldn't talk the guy outta it, told him it was the wrong engine and superchargers suck in general but he wouldn't listen. Last time that thing ran half decently was during break in.[sm=lol.gif]
Wolfie1
Just curious, what was the Temp on your motor once up to normal operating Temp? I just bought my XL about a month ago, 3 tanks so far, when I tune it ( to how I think it runs correctly, it runs around 280 – 300 degrees, if I tune it to where it runs around 250 degrees, top end SUCKS. This is with the body on. I cut a hole in my front grille trying to get air flow to the engine, didn’t help. I have the back bed area cut halfway back and all of the back windshield cut out. I can’t get the freaking thing to run around 250 without sucking on the top end. So, I’m curious if I may have a bad engine or it’s just gonna run hot til it blows up….
I’m using Duratrax – Flashoint temp gauge, it does not have a laser but I have put it in the same location every time. Don’t know if it sucks or what but seems to read Temp correctly.
Does anyone have suggestion on cooling my engine?
If you are at 280-300 degreesF and the engine runs great with enough smoke coming out the stinger when you gas it and the engine does not make bad noises, then 280-300degreesF is where you need to be.
That 250-275degree range is wrong for so many reasons. One being your location; you can be at a higher altitude. You can ave more humididty or less humidity. Your outside temps could be wramer or colder than usual.
The fuel nitro % also plays a part where your temps likt to be at. Also, the same for you plug choice.
Totally ignore the temp range in the HPI manual and tune to feel at the trigger, the sounds the engine makes, and the smoke coming out of the stinger. Then, temp you engine and memorize the temp range the engine behaves the best.
Also I heard stuff about that duracrap flashpoint.
Something like it has to be set at 77E or some crap like that.
To test the accuracy the next time you are cooking in the oven temp the oven and see if it jives. (I have heard that different heads/glow plugs with silver or black makes a difference so...?)
I wouldn't trust or use the temp gun as a guide.
Only as a second opinion.
You should point it directly at the glow plug, I rest mine right on the head pointing down the hole.
Like Jim said smoke and sound.
If you have a high jittery sound after a high speed pass you are lean or have an air leak.
Lean jitters is a bad sound you don't want to hear.
Also always set your final tune after the engine is fully warmed up.
The Savages lean out when the fuel gets low so if you tune at 1/2 tank it will help keep it rich enough when the fuel gets low.
Cut a hole in the windshield directly in front of the engine.
Hope some of that helps
SLAYER
cheers
Just make sure you buy one that is not made in china; the chinese ones are unreliable (these are the ones that cost like $50-60 USD).
270 to 300 seems to be their operating range. My modded 5.9 runs much cooler and makes a lot more power. I know mine went over 330 several times.
Mine runs great!
The 3 guys that I told to buy the 5.9XL have great running XL's as well.
I did give them tuning tips while they got the hang of nitro...
Not just nitro noobs you have heard blowing engines or anything I hope.
Here's what my XL 5.9 had to say about gallon #7
[youtube]http://www.youtube.com/watch?v=sEHzkGSei_4[/youtube]
To help quench some of that heat in between combustions, you might want to go with 30% nitro because it is more volatile and will take more heat with it away as it evaporates. (The evaporation actaully also helps in better dispersing the fuel into the air to help combustion of your next powerstroke).
For your engine, actually, I think you might be running it a bit richer than what ite should be. Is your engine fully broken in yet? If not, then continue to keep it on this rich side.
Other than that, carry on soldier!
Just to account for that hot Texas heat, you might want to give more leeway to running a bit hotter than 255degreesF. Since you are Killeen, I can gaurantee you will see about 110 degrees outside with heat index, and thta could push your engine to higher temps, especially at 1700hrs (just about the hottese of the day).
On another note, I can't get 30% anywhere around Killeen The closest place is in Dallas, which is a 2.5 hour drive. Not quite worth the trip. So, here's my proposition to you Jim, if you could pick up some Byron's 30%, I'll send you the money and you could hopefully mail it to me?
You wouldn't have to worry about HAZMAT shipping charges b/c the good 'ol United States Postal Service will allow you to bring in a box that's already sealed and ship it without ever opening it. Get a flat-rate box and BAM-O. We can discuss what you'd want to charge for the hassle if you think this sounds like a good proposal. Please?
