Flux diff questions????
I have had my Flux for about 7 months now. And today while I was running it I heared a grinding sound then noticed that the rear wheels weren't moving when I gave it some throttle. So now I have the rear diff apart and all of the gears have their teeth. So what could have been causing my problems?
RE: Flux diff questions????
Did you check your set screws? Also I would opened up the transmission and check the gears, I bet you that they are all stripped as well.
it is likely a set screw in your rear center dogbone. the same thing happened twice to me with my nitro savage. some blue loctite will fix that.
it could also be one of the rear dogbones either missing, or broken.
ORIGINAL: scarletboa
Time to switch it out. Here I see the bevel set on ebay for cheap - http://cgi.ebay.com/ws/eBayISAPI.dll...m=190334726885
ORIGINAL: t9dragon
ORIGINAL: black mamba
Did you check the spider gears inside the diff?
ORIGINAL: t9dragon
