RPM stablemaxx wheels on a savage xl
MO
[img]file:///C:/DOCUME~1/MATT/LOCALS~1/Temp/moz-screenshot.jpg[/img]Anyone have the RPM chrome revolver wheels on their XL. Please post a picture if you do. I'd like to see what they look like on this truck.
Iguess the HPIterra pin tires would slide right on these wheels as well???? Anyone know?
http://www.rpmrcproducts.com/product...r/Revolver.htm
They have 1/2" offset so they will make the truck a bit more stable.
VT
RE: RPM stablemaxx wheels on a savage xl
yes to the offset part, and they should fit right on but i have no pics to show
i'd check they're 14 or 17mm hubs if they're 14 i'd just pass on them
the lug
the lug
The XL is already extremely wide for its size. If you make it 1" wider it will not be as stable while trying to go in a straight line.
Just my thought on that matter.
The terra pins will fit and RPM makes a stablemax that does have a 17mm wheel hex.
KS
I found them to make my XL better in cornering and almost impossible to keep straight at speed. They are very rough on shocks, uprights and turnbuckles! That tire has a lot of leverage out there on that extended axle, plus a half inch. I loved them in the sand and have a set with paddles on them. Glen
