Carb problem?
ON, CANADA
Carb problem?
Hey guys, my truck was sitting in a garage for about a year, so I try and start it with no luck, it seems that there is no gas getting through, If I recall I remember pluging the exaust pipe with my finger and the fuel would leak out of there, now everything is dry
all hoses are clear, seems like the carb isn't sucking the fuel in or something, any ideas?
PA
RE: Carb problem?
dump alittle fuel in the neck of the carb and see if she fires up. If she fires up then the inlet is blocked. If Iknow that a nitro motor has been sitting for awhile I tear down the carb and clean it, just incase the fuel has gummed up.
ON, CANADA
RE: Carb problem?
sweet, I cleaned and blew and the carb is pumpin, thanks guys, I will test it out tomorrow after work, it's to late tonight, Thanks again.
