rebuilding a 5.9?
RE: rebuilding a 5.9?
have you got the intruction manual? if not, download from HPI website. it's the reverse to disassembly.
things to watch out for are replace old gaskets if required to stop air leaks. if you need additional hi temp sealant the for sure. dun overtighten the screws and make sure the piston faces the correct way, cutout facing forwards on assembly. makes sure you oil the bearings and the pistion before sliding into sleeve.
cheers
etops
cheers
etops
KS
A piston and sleeve should do you just fine. I have one with about 12 gallons on it and as much as I hate the Kingstar line, that crank is still good. I had Supertib mod it and he said it was much softer and easier to cut than a Picco. Maybe, but it is holding up great so far. It has lived primarily on 30 percent Byrons Gen 2 Race Fuel, along with some quarts of Trinity 35 percent Monster Horsepower.
I agree though, apply the money towards an LRP 30 or Picco 28. Just last night I had another K5.9 owner I met through You Tube with a broken piston. The photo he sent me are all too familiar... It sucks, but that is the way it is... Glen
TX
ORIGINAL: BudBud
maybe i'll just gonna get an lrp.30 and rebuild the 5.9 as a spare engine hey is it okay to reuse the old gasket? this is my first time rebuilding an engine,what do you use to clean the internal and external part of the engine?
thanks
