savage flux question?
RE: savage flux question?
the mamba monster motor and the savage flux motor are one in the same so if your thinking its better there just the same motor, i could be wrong though
but if you want to you will have to shave some off the inside of the motor mount to get it to fit.
the outside cooling fins are very different. i bought this because i was having problems with the stock stuff. i have posted in another thread " flux problems"
yeah but they are the same just a different casing, but like i said you will need to shave the inside of the motor mounts a little to get them to clear the fins on the mama monster, sounds like you need to get a 2.4 ghz radio system am is ok fm is good but 2.4 ghz is the best and glitch free. hope this helps
