Savage Brushless Systems?
Hey Guys, I`m 14 and got a free Savage X SS last year in home schooling, (we have a budget from the government to get educational stuff for home schooling) and now this year I want to try and get a brushless system for my Savy, any suggestions? I would like to keep it as low as possible (probably under $250) and I know I cant get a Flux system or something, I was looking at things like this - http://www.hobbypartz.com/07e-c-combo-m3a.html (yeah I know they aren`t the greatest, just a suggestion). So I`m looking to swap out the 4.6 and put a brushless system in, what will I need to do this?
Thanks Guys!
Ray
Thanks Guys!
Ray
OH
RE: Savage Brushless Systems?
The hobbywing stuff gets great reviews, and the Hobbywing 35a system in ThunderbirdJunkie's on road car has been decent.
Can't speak for that specific model, though. Good luck, Ray!
Thanks TBJ! I think I have something firgured out, a "Novak HV Pro Brushless System 6.5T w/5mm Rotor" motor and ESC combo for $170, and then the HPI Flux mount and battery compartments, and a LiPo Charger and a 2S LiPo, all that is a little over $250, but what size pinion should I use? RC Person, I`m gonna put the big block in my T-Maxx, but that system is pretty expensive..
Here`s the links to what I`m thinking - http://www3.towerhobbies.com/cgi-bin...?&I=LXUYD8&P=7 - http://www3.towerhobbies.com/cgi-bin...?&I=LXWVC3&P=7 - http://www3.towerhobbies.com/cgi-bin...?&I=LXWVC7&P=7 And then just a Duratrax 2S LiPo and a $40 charger from HP.com
Ray
Ray
OH
Ray, one thing to remember; the Flux mount won't work with most motors. It's built to clamp around the can, and the Castle motor the Flux comes with is 40mm diameter. It would definitely behoove you to look into building your own mount or using something that's preexisting for 36mm motors for that Novak.
Should have some parts here in the next couple days so hopefully will have some pictures for an example.
i'm currently using that hobbywing xerun 150A and the 4274 motor on my flux... you have to mod the motor mount.. it wont fit the 4274...
Could I cut down that little black tube thing where the screw goes through and bend the mount down a bit make it fit?
Ray
Ray
NY
I would go with 3s or 4s, it will be not very fast with only 2s... make sure your batteries can supply enough amps (mah*c rating/1000) I would say at least 150 amps to be safe, 5000mah 30c. If they can't, you will cog a lot, and your batteries will get hot and maybe puff up (not good).
good luck, Novak's are very good systems.
Maybe get that ESC with a Castle motor. idk, just a thought...
ORIGINAL: rc person 577
Ray
ORIGINAL: Khraih
Yeah I want to go with 4s, but then it would be over $300, so I`m just gonna get the 2s for now (probably wont even use it till I get another). How fast would you guys say a Savy can go with that Novak? Oh yeah and what size pinion should I use? I`m also thinking of getting a Mamba Monster for $270 instead..
Ray
Ray
Side not you will need a few parts to do the conversion. In the tranny you will need a flux idler gear(around $7-9) to get the ESC to reverse, and break. You also might need stronger dogbones. Also a way to mount the batteries. When I made mine I tried keeping as many stock parts as possible. In the next month or 2 I'm going to order that same HW combo cause I've only had good experiences with my HW esc's
And for lipos you can always look at hobbyking. They sell them very reasonably. I use 2X 2S 5200 30C hardcases and they don't even get warm going full throttle non stop . You will need 4S cause the power draw off a 2S will damage it
ORIGINAL: SyCo_VeNoM
I got the mamba monster tried it in my Savage .25 conversion don't recommend it. I got the 2200kv and that sucker backflips faster than hell on 4S after I dropped its gearing down. It was also getting extremely hot very fast. Also the pinion it comes with is crap I turned the castle pinion into a shiny tiny wheel in 15 seconds with the wheels of the savage off the ground. IMO The NEU motors VERY nice, too powerful for most applications(hell my truggy its in now does backflips at half throttle and I geared that low too). The ESC I really don't like I've had issues getting it to work with my radio I had, and had to buy another radio to use it.
Ray
ORIGINAL: Khraih
Yeah I dont know if I`m gonna get the Mamba, pretty expensive (not really compared to others lol!) I think I`ll stick with the Novak. You said you got a 2200kv and it backflips, is that the Mamba? Do you have a link to the idler gear? I think the X SS dog bones will be good, it says they are heavy duty! I was just going to get the Flux battery boxes and mod then to fit. I`m gonna squeeze in another 2S so then I will have 4s total. How fast do you think a Savy will be with the Novak HV Pro 6.5T (or is the 5.5 better?) on 4S? I guess it wont be able to do a standing backflip like the Flux, lol. Thanks man!
Ray
Ray
http://www.rcuniverse.com/forum/m_96...tm.htm#9675598 pics of mine I slapped stampede chassis to the side to make battery box's for now. Eventually I want to pick up Flux TVP's (maybe the XL ones) and flux battery box's but they work fine for now
HPI100905 was the gear its like $8 on ebay
Ray
If its 2200kv it probably will flip. Ohh yea you will need a new spur gear the 52t will be slow as hell.
I dropped it to 12t pinion gear which keeps it off its top somewhat. In 10 minutes of testing I actually wrecked a new lexan shell and ate a good chunk off the roll bar.
Side note what ever way you go ESC wise be sure to set it to drag brake. Before I changed the setting on the MM combo the truck would literally flip forward on braking and fly like 9 feet (main reason the shell I mentioned above was trashed)
Ray
Okay everyone, I`m gonna be getting doing to brushless conversion soon, but I need to know what is a good overall size pinion for speed and torque with a 47 tooth spur running the Novak 5.5 brushless system, I need to know ASAP!
Thanks!
Ray
Thanks!
Ray
ORIGINAL: Khraih
Thanks!
Ray
Thanks!
Ray
ORIGINAL: mac3194
i would go with an 18T pinnion
Ray
ORIGINAL: t9dragon
I personally would use a different BL seup then the Novak.
Ray
well stock gearing on a savage flux is 42/20 so i think 18 is good with a 47... well thats what im running. i think u should get the hobby wing esc instead of the novak or try to find a good deal on a used mamba monster.
