ThrottlrTrim Adj
TX
ThrottlrTrim Adj
Is it okay to adjust my throttle trim just like in the picture? currently my adjustment is in the center,but the problem is if i want to increase my idle it doesn't open up much, is that gonna harm the servo if i use my desired adjustment
RE: ThrottlrTrim Adj
Ideally you want to have the engine set up to run properly on the idle screw in the carburator ...using trim to set your idle will just cause the truck to stall every time you hit the brakes-scott
