Savage Flux toe-in/toe-out front/rear wheels?
On a Savage Flux should there be any toe-in or toe-out on either the front or rear wheels? Does it matter on the type of tire being used? I have the stock wheels/rims and a set of Crimefighters...
RE: Savage Flux toe-in/toe-out front/rear wheels?
There is no way to adjust either of those unless you have changed out the plastic links with tierods.
He said tow in and tow out, Not camber,
on my flux I have the alloy hubs fitted to the rear and these have a slight preset tow in, On the front I run a slight tow out to compensate for when it's on power, which is when the wheels will pull straight, Tow in on the rear is suppose to help cornering and straight line steadiness. |
