Nitro Fuel
What is the best brand and where I can buy 20% to 25% Nitro Fuel?
The best brand is Byron gen2 or powermasters. Buy it at the local hobby store.
how much percent nitro do you guys run?
Hi Rich,
I've used several fuels, none of which I recommend over the others. I will use Odonells 20% nitro 10-12% lube, as I can source it locally.
Amazon sent me a gallon of Torco 20% nitro 14% lube, but that is about $40 shipped. I don't see that available at the moment.
Other online store sent me Powermaster 20% quart.
Your engine manufacturer should probably give you recommendations for break-in and running fuel.
Generically, from things Ive read and been told:
Use 20% nitro until you can prove you want/need something different
Use 10-14% lube with some castor oil in blend, for break-in and running. Bias high in range for break-in, and lower in for running.
There is a load of info on nitro fuel and lubricants, and expect to become knowledgeable on the subject.
Happy running.
Happy running.
Previous Thread
Next Thread
