HPI Reload v2 box
Hi there.
I connected my Flux Reload v2 box to my PC today and updated the box to v3. But then it did not work against the car. So when i disconnected the pc from the box and connected the box to ecu it would not work? The ECU I use is: Flux EMH-3S speed controller. Do not understand why an update of the box should make it not work against the car? Updated ECU for latest update as well |
First, get in touch with HPI's support. They might have insight to getting your ESC up and running. Bad download? If you have issues, surely others are as well. HPI needs to know about this. In the meantime, I'd use the Setup button, on the ON/OFF switch, to select a parameter that needs changed.
Hello.
I have speak with HPI support, and my ECU is okay now, and everything works fine. I updated the ECU, and I updated the Reload v2 box to v3 and when I connect the ECU to the box, it's not working. But when I update the reload box to versjon v2 all working again. someone know why reload box v3 not working with the ECU, but reload v2 does? |
Firmware upgrading is sometimes not the best option. Most of times it is. Sometimes things get garbled in a download or bad script leaves unseen results until some beta testing is done, and even then "bugs" maybe unfound in the firmware. I'm glad you were able to at least reinstall previous firmware version. Let HPI know so they have a record of it and can possibly work on the next revision/version ;).
