Ikarus Aerofly flight simulators Get the answers to your technical questions about Ikarus' Aerofly flight simulators here in their official support forum
application crash
Reply
Old 01-03-2011, 03:43 PM
nickffc
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default application crash
Only had AFPD loaded on my MAC for a few days now and really been playing it to death....!
but as of a few hours ago the programme keeps crashing....?
a box pops up saying that the application has unexpectantly quit and the quit infomation has been sent to apple....
to options i get are QUIT OR REOPEN APPLICATION
when i reopen all seems fine, everything loads it "see's" the transmitter (DX6i) and then i am taken to the main menu
its not untill i hit the "fly" button then it all crashes again.....? confused.com.....!!
system details
Model Name: iMac
Model Identifier: iMac8,1
Processor Name: Intel Core 2 Duo
Processor Speed: 2.8 GHz
Number Of Processors: 1
Total Number Of Cores: 2
L2 Cache: 6 MB
Memory: 4 GB
Bus Speed: 1.07 GHz
Boot ROM Version: IM81.00C1.B00
SMC Version (system): 1.30f1
Nick
nickffc is offline
Old 01-04-2011, 05:50 AM
rajul
My Feedback: (58)
rajul's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: application crash
Nick, which Mac OSX and video card are you using?
rajul is offline
Old 01-04-2011, 10:16 AM
nickffc
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi Mike
MAC OSX 10.6.5
2.8 Ghz
ATIRadeon HD2600 Pro 256mb VRAM
Nick
nickffc is offline
Old 01-04-2011, 03:22 PM
rajul
My Feedback: (58)
rajul's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
What is the version number printed on your disk? Did you install any patch? Please post the tm.log file which you can find in the main AFPD directory. You may open the file with a text editor. Just copy and paste the entire content into your post.
rajul is offline
Old 01-05-2011, 10:23 AM
nickffc
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi Mike
patch done
version : 1.11.07.25
tm log
tm: Library Version 4.2d, Copyright (C) 1998-2009, IPACS
tm: http://www.ipacs.de
openal: init structs
openal: init (default=Built-in Output) (0:Built-in Output) (using default device) (version=1.1) (1.1) (Built-in Output) (Built-in Output) ok
tmsystem: mac os version=10.65
loading font v2 texture/fontuni.tff=(2048x2048) (h=16) (nc=65536) (split=1) ok
tmgl: loading mouse texture/mouse.tmt=ok
tmprogram: AeroFly Professional Deluxe Version 1.11.07.31, Copyright (C) 1998-2009 IPACS
loading configfile config/main.mcf=ok
loading player configfile config/player1.mcf=ok
loading player configfile config/player2.mcf=ok
openal: register sound sound/beep.wav=(0, rd=100.00) ok
openal: register sound sound/balloon.wav=(1, rd=100.00) ok
openal: register sound sound/crash.wav=(2, rd=100.00) ok
openal: register sound sound/splash.wav=(3, rd=100.00) ok
openal: register sound sound/glider.wav=(4, rd=2.00) ok
openal: register sound sound/glider2.wav=(5, rd=2.00) ok
openal: register sound sound/glider.wav=(already registered)(6, rd=5.00) ok
openal: register sound sound/glider2.wav=(already registered)(7, rd=5.00) ok
openal: register sound sound/glider.wav=(already registered)(8, rd=2.00) ok
openal: register sound sound/glider2.wav=(already registered)(9, rd=2.00) ok
openal: register sound sound/glider.wav=(already registered)(10, rd=5.00) ok
openal: register sound sound/glider2.wav=(already registered)(11, rd=5.00) ok
afdesign: init ok
gl: vendor=ATI Technologies Inc., renderer=ATI Radeon HD 2600 PRO OpenGL Engine, version=2.1 ATI-1.6.24
gl: (viewport=8192x8192) (texturesize=2048) (stencil=8)
gl: extensions=GL_ARB_transpose_matrix GL_ARB_vertex_program GL_ARB_vertex_blend GL_ARB_window_pos GL_ARB_shader_objects GL_ARB_vertex_shader GL_ARB_shading_language_100 GL_EXT_multi_draw_arrays GL_EXT_clip_volume_hint GL_EXT_rescale_normal GL_EXT_draw_range_elements GL_EXT_fog_coord GL_EXT_gpu_program_parameters GL_EXT_geometry_shader4 GL_EXT_transform_feedback GL_APPLE_client_storage GL_APPLE_specular_vector GL_APPLE_transform_hint GL_APPLE_packed_pixels GL_APPLE_fence GL_APPLE_vertex_array_object GL_APPLE_vertex_program_evaluators GL_APPLE_element_array GL_APPLE_flush_render GL_APPLE_aux_depth_stencil GL_NV_texgen_reflection GL_NV_light_max_exponent GL_IBM_rasterpos_clip GL_SGIS_generate_mipmap GL_ARB_imaging GL_ARB_point_parameters GL_ARB_texture_env_crossbar GL_ARB_texture_border_clamp GL_ARB_multitexture GL_ARB_texture_env_add GL_ARB_texture_cube_map GL_ARB_texture_env_dot3 GL_ARB_multisample GL_ARB_texture_env_combine GL_ARB_texture_compression GL_ARB_texture_mirrored_repeat GL_ARB_shadow GL_ARB_depth_texture GL_ARB_shadow_ambient GL_ARB_fragment_program GL_ARB_fragment_program_shadow GL_ARB_fragment_shader GL_ARB_occlusion_query GL_ARB_point_sprite GL_ARB_texture_non_power_of_two GL_ARB_vertex_buffer_object GL_ARB_pixel_buffer_object GL_ARB_draw_buffers GL_ARB_shader_texture_lod GL_ARB_color_buffer_float GL_ARB_half_float_vertex GL_ARB_texture_rg GL_ARB_texture_compression_rgtc GL_ARB_framebuffer_object GL_EXT_compiled_vertex_array GL_EXT_draw_buffers2 GL_EXT_framebuffer_object GL_EXT_framebuffer_blit GL_EXT_framebuffer_multisample GL_EXT_texture_rectangle GL_ARB_texture_rectangle GL_EXT_texture_env_add GL_EXT_blend_color GL_EXT_blend_minmax GL_EXT_blend_subtract GL_EXT_texture_lod_bias GL_EXT_abgr GL_EXT_bgra GL_EXT_stencil_wrap GL_EXT_texture_filter_anisotropic GL_EXT_separate_specular_color GL_EXT_secondary_color GL_EXT_blend_func_separate GL_EXT_shadow_funcs GL_EXT_stencil_two_side GL_EXT_texture_compression_s3tc GL_EXT_texture_compression_dxt1 GL_EXT_texture_sRGB GL_EXT_blend_equation_separate GL_EXT_texture_mirror_clamp GL_EXT_packed_depth_stencil GL_EXT_bindable_uniform GL_EXT_texture_integer GL_EXT_gpu_shader4 GL_EXT_framebuffer_sRGB GL_EXT_provoking_vertex GL_APPLE_flush_buffer_range GL_APPLE_ycbcr_422 GL_APPLE_rgb_422 GL_APPLE_vertex_array_range GL_APPLE_texture_range GL_APPLE_float_pixels GL_ATI_texture_float GL_ARB_texture_float GL_ARB_half_float_pixel GL_APPLE_pixel_buffer GL_APPLE_object_purgeable GL_NV_blend_square GL_NV_fog_distance GL_NV_conditional_render GL_ATI_texture_mirror_once GL_ATI_blend_equation_separate GL_ATI_blend_weighted_minmax GL_ATI_texture_env_combine3 GL_ATI_separate_stencil GL_ATI_texture_compression_3dc GL_SGIS_texture_edge_clamp GL_SGIS_texture_lod GL_SGI_color_matrix GL_EXT_texture_array GL_EXT_vertex_array_bgra GL_ARB_instanced_arrays GL_ARB_depth_buffer_float GL_EXT_packed_float GL_EXT_texture_shared_exponent
gl: extensions=(separate color) (anisotropic filter of 16.00) (compressed texture) (cubemaps) (shader) (framebuffer)
framebuffer object created (1024, 1024)
framebuffer object created (256, 256)
tminput: searching for input devices...(3)
tmsystem: searching usb interface (0,0) 0=radiointerface
tmsystem: searching dummy usb interface (0) 1=unable to open interface device
tmsystem: searching dummy usb interface (0) 1=unable to open joystick device
tminput: 1 devices found
license (A040-40860299.lic): entries=49
sim: loading scenery scenery/herrieden.geo...
sim: 1 objects 0 dynobjects
sim: start position (3ds) multi pano 1 (not for airplanes)
sim: start position (3ds) multi pano 2 (not for helicopter)
sim: start position (3ds) multi pano 3 (not for helicopter)
sim: start position (3ds) multi pano 4
sim: start position (3ds) multi pano 5
sim: shadowcolor=0.0000 0.0200 0.0300 0.8000
sim: load texture grid 8x8 (pano=0) (compress=1) named herrieden/herrieden=(3.750x4.500) (8x8) (12x6)
sim: sphere 3ds params(0)=0.4000 0.5210 -162.3010
sim: photo pos(0)=0.0000 0.0000 1.6600
sim: sphere offset(0)=0.0000 0.0000 -10.0000
sim: loading ground object scenery/herrieden/herrieden.obj=ok
sim: loading time=574067 mus
sim: 1 photo scenes
tmcollision: 36753 triangles using 4704384 bytes
tmcollision: omin=(-2444.6,-2399.1,-31.3) omax=(2324.1,2369.6,46.7) octmin=(10.0,10.0,10.0)
tmcollision: otnodes=841 otendnodes=421 otdepth=21 otlistareas=605768
tmcollision: otnmaxareas=1097 otnavgareas=116 otnminsize=(9.314,9.314,9.747)
tmcollision: otareas=49105 mem=4900804
tmcollision: 841 octrees, using 127832 bytes
tmcollision: total mem=5028636 bytes
tmcollision: time=0.16s
tmcolldynamic: no dynamic objects or triangles
sim: loading aircraft 1 a109...
openal: register sound sound/blade1.wav=(12, rd=5.14) ok
openal: register sound sound/gheli1.wav=(13, rd=5.14) ok
generating shadow 0=radius=2.50 bbmin=(-1.63 -1.63 -0.35) bbmax=(1.63 1.63 0.40)
sim: creating blurr=Rotor
sim: creating blurr=TailRotor
loading input device calibration config/radio0.tmc=ok
tmsystem: calibrating radio deviations= 0 3 6 9 -16 25 (timer=5983) -36 4) 88 (BF79FD66)
license: tml file 'afpd-a040.tml' = A040 0000 0000 0000 'AeroFly Professional Deluxe Platinum Edition' 'A040-40860299.lic' (activated=1)
saving configfile config/main.mcf=ok
saving player configfile config/player1.mcf=ok
openal: shutdown=ok
nickffc is offline
Old 01-07-2011, 08:22 AM
rajul
My Feedback: (58)
rajul's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Did you make any changes to your mac system, or installed any new software/application/hardware, before the problem occurred? It was running fine previously as noted.
rajul is offline
Old 01-07-2011, 02:41 PM
nickffc
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi Mike
no nothing has changed..... AFPD was working fine since you fixed the registration problem i had before.
have used the programme without any problems for about 6-8 hours over two days changing from all sorts of aircraft and different scenery.
have tried going to an aircraft and scenery combination that i have used successfully before but that didn't work....?
there is an apple report that comes up when the programme crashes would you like me to PM that to you...?
Nick
nickffc is offline
Old 01-07-2011, 02:44 PM
nickffc
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
would reinstalling the programme work....?  would i have a problem with registration if i did this....?
nick
nickffc is offline
Old 01-07-2011, 03:45 PM
nickffc
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
just thought of something..... i have downloaded a few other aircraft from another website..... could this be a cause...?
nick
nickffc is offline
Old 01-07-2011, 03:53 PM
rajul
My Feedback: (58)
rajul's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I think you could try to do a complete uninstall and reinstall. You can activate and reactivate using the new key without any problems. Yes, it could be something to do with the installation of the other models, could be that they are not compatible with mac afpd or the installation caused a program corruption. If you could give me the link to these models, I could check
rajul is offline
Old 01-07-2011, 05:25 PM
nickffc
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
are you aware of any hidden files that i should look for to deleat or are all AFPDfile within the AFPDfolder...?
Nick
nickffc is offline
Old 01-07-2011, 05:36 PM
rajul
My Feedback: (58)
rajul's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
It can be complicated, so a full uninstall/reinstall is easier
rajul is offline
Old 01-09-2011, 03:52 AM
nickffc
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hey Mike
All working again....has stopped once or twice in 2 hours of running but at least it's working for now.
i could not find an uninstaller for the programme so i just dragged and dropped into the trash can....
i had to have 2 trys at installing as the first time the programme wouldn't even open....?
do you know if there is an upcoming patch for these glitches...? or would upgrading to 5.5 be any help...?
thanks for your help...again...
Nick
nickffc is offline
Old 01-09-2011, 03:57 AM
rajul
My Feedback: (58)
rajul's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Pls install the latest 1.11.7.31 patch for mac afpd http://www.aerofly.com/afpd/downloads.html
You might also want to check if your computer system has adequate cooling as an overheated videocard can result in crashes as well
rajul is offline
Old 01-09-2011, 05:37 AM
nickffc
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
yep did the patch update already....
cooling is good on the Mac.... never had an issue before with overheating....
nickffc is offline
Contact Us Archive Advertising Cookie Policy
