Ikarus Aerofly flight simulators Get the answers to your technical questions about Ikarus' Aerofly flight simulators here in their official support forum
AFDP display problem with Radeon 5770
Reply
Old 01-14-2011, 11:16 AM
dbrickma
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default AFDP display problem with Radeon 5770
Hello,
I recently upgraded my computer and display and am trying to run Aerofly Professional Deluxe at a native screen resolution of 1920x1200. Only a portion of the 1920x1200 screen is displayed; the lower and right-hand portions are truncated. The new system is:
AFPD version 1.11.07.21, no addons
Processor: Intel Core i7-950
Memory: 6GB
O/S: Windows 7 64-bit Home Premium (6.1 build 7600) with DirectX 11
Graphics: Sapphire Radeon 5770 with 1GB DDR5 with 64-bit Catalyst 10.12 (Driver version 8.801.0.0)
Display: HP ZR24w
The tm.log file is appended below.
I moved the display to a second system running Windows 7 32-bit Home Premium with an Nvidia 8600GT and verified that it correctly displayed 1920x1200. So my questions are:
Is AFDP known to work with 64-bit Windows 7 and a Radeon 5770? (If yes, I have some other problem.)
If not, does this configuration run with Aerofly 5? (I would like to upgrade.)
Thanks, Don Brickman
Tm.log begins:
tm: Library Version 4.4, Copyright (C) 1999-2007, IPACS
tm: http://www.ipacs.de
tmsystem: init random with 1349278842
tmsystem: cpu type=(nlogical=1) (nphysical=8) (no hyper-threading)
tmsystem: cpu=3073 Mhz
tmsystem: memory=(physical=4095MB, avail=4095MB) (virtual=2047MB, avail=1854MB)
tmsystem: operating system=Microsoft Windows Vista Version 6.1 (Build 7600)
loading font v2 texture/fontuni.tff=(2048x2048) (h=16) (nc=65536) (split=1) ok
tmgl: loading mouse texture/mouse.tmt=ok
tmprogram: AeroFly Professional Deluxe Version 1.11.07.21, Copyright (C) 1998-2008 IPACS
loading configfile config/main.mcf=ok
loading player configfile config/player1.mcf=ok
loading player configfile config/player2.mcf=ok
openal: register sound sound/beep.wav=(0, rd=100.00) ok
openal: register sound sound/balloon.wav=(1, rd=100.00) ok
tmgl: failed to load texture texture/photoeye.bmp
openal: register sound sound/crash.wav=(2, rd=100.00) ok
openal: register sound sound/splash.wav=(3, rd=100.00) ok
openal: register sound sound/glider.wav=(4, rd=2.00) ok
openal: register sound sound/glider2.wav=(5, rd=2.00) ok
openal: register sound sound/glider.wav=(already registered)(6, rd=5.00) ok
openal: register sound sound/glider2.wav=(already registered)(7, rd=5.00) ok
openal: register sound sound/glider.wav=(already registered)(8, rd=2.00) ok
openal: register sound sound/glider2.wav=(already registered)(9, rd=2.00) ok
openal: register sound sound/glider.wav=(already registered)(10, rd=5.00) ok
openal: register sound sound/glider2.wav=(already registered)(11, rd=5.00) ok
afdesign: init ok
directinput: init=ok
tmsystem: current monitor frequency=60
init window=(window=1920x1200) (screen=1298x811) (32bpp) (60Hz) (fullscreen)
openal: init (default=Generic Software) (0:Generic Software) (using default device) (version=1.1) (1.1) (Generic Software) (Generic Software) ok
init pixelformat=ok
gl: vendor=ATI Technologies Inc., renderer=ATI Radeon HD 5700 Series, version=4.1.10362 Compatibility Profile Context, opengl version=4.1
(viewport=16384x16384) (texturesize=16384) (stencil=8)
gl extensions=GL_AMDX_debug_output GL_AMDX_vertex_shader_tessellator GL_AMD_conservative_depth GL_AMD_debug_output GL_AMD_depth_clamp_separate GL_AMD_draw_buffers_blend GL_AMD_name_gen_delete GL_AMD_performance_monitor GL_AMD_sample_positions GL_AMD_seamless_cubemap_per_texture GL_AMD_shader_stencil_export GL_AMD_texture_cube_map_array GL_AMD_texture_texture4 GL_AMD_transform_feedback3_lines_triangles GL_AMD_vertex_shader_tessellator GL_ARB_ES2_compatibility GL_ARB_blend_func_extended GL_ARB_color_buffer_float GL_ARB_copy_buffer GL_ARB_depth_buffer_float GL_ARB_depth_clamp GL_ARB_depth_texture GL_ARB_draw_buffers GL_ARB_draw_buffers_blend GL_ARB_draw_elements_base_vertex GL_ARB_draw_indirect GL_ARB_draw_instanced GL_ARB_explicit_attrib_location GL_ARB_fragment_coord_conventions GL_ARB_fragment_program GL_ARB_fragment_program_shadow GL_ARB_fragment_shader GL_ARB_framebuffer_object GL_ARB_framebuffer_sRGB GL_ARB_geometry_shader4 GL_ARB_get_program_binary GL_ARB_gpu_shader5 GL_ARB_gpu_shader_fp64 GL_ARB_half_float_pixel GL_ARB_half_float_vertex GL_ARB_imaging GL_ARB_instanced_arrays GL_ARB_map_buffer_range GL_ARB_multisample GL_ARB_multitexture GL_ARB_occlusion_query GL_ARB_occlusion_query2 GL_ARB_pixel_buffer_object GL_ARB_point_parameters GL_ARB_point_sprite GL_ARB_provoking_vertex GL_ARB_sample_shading GL_ARB_sampler_objects GL_ARB_seamless_cube_map GL_ARB_separate_shader_objects GL_ARB_shader_atomic_counters GL_ARB_shader_bit_encoding GL_ARB_shader_objects GL_ARB_shader_precision GL_ARB_shader_stencil_export GL_ARB_shader_subroutine GL_ARB_shader_texture_lod GL_ARB_shading_language_100 GL_ARB_shadow GL_ARB_shadow_ambient GL_ARB_sync GL_ARB_tessellation_shader GL_ARB_texture_border_clamp GL_ARB_texture_buffer_object GL_ARB_texture_buffer_object_rgb32 GL_ARB_texture_compression GL_ARB_texture_compression_bptc GL_ARB_texture_compression_rgtc GL_ARB_texture_cube_map GL_ARB_texture_cube_map_array GL_ARB_texture_env_add GL_ARB_texture_env_combine GL_ARB_texture_env_crossbar GL_ARB_texture_env_dot3 GL_ARB_texture_float GL_ARB_texture_gather GL_ARB_texture_mirrored_repeat GL_ARB_texture_multisample GL_ARB_texture_non_power_of_two GL_ARB_texture_query_lod GL_ARB_texture_rectangle GL_ARB_texture_rg GL_ARB_texture_rgb10_a2ui GL_ARB_texture_snorm GL_ARB_timer_query GL_ARB_transform_feedback2 GL_ARB_transform_feedback3 GL_ARB_transpose_matrix GL_ARB_uniform_buffer_object GL_ARB_vertex_array_bgra GL_ARB_vertex_array_object GL_ARB_vertex_buffer_object GL_ARB_vertex_program GL_ARB_vertex_shader GL_ARB_vertex_type_2_10_10_10_rev GL_ARB_viewport_array GL_ARB_window_pos GL_ATI_draw_buffers GL_ATI_envmap_bumpmap GL_ATI_fragment_shader GL_ATI_meminfo GL_ATI_separate_stencil GL_ATI_texture_compression_3dc GL_ATI_texture_env_combine3 GL_ATI_texture_float GL_ATI_texture_mirror_once GL_EXT_abgr GL_EXT_bgra GL_EXT_bindable_uniform GL_EXT_blend_color GL_EXT_blend_equation_separate GL_EXT_blend_func_separate GL_EXT_blend_minmax GL_EXT_blend_subtract GL_EXT_compiled_vertex_array GL_EXT_copy_buffer GL_EXT_copy_texture GL_EXT_direct_state_access GL_EXT_draw_buffers2 GL_EXT_draw_instanced GL_EXT_draw_range_elements GL_EXT_fog_coord GL_EXT_framebuffer_blit GL_EXT_framebuffer_multisample GL_EXT_framebuffer_object GL_EXT_framebuffer_sRGB GL_EXT_geometry_shader4 GL_EXT_gpu_program_parameters GL_EXT_gpu_shader4 GL_EXT_histogram GL_EXT_multi_draw_arrays GL_EXT_packed_depth_stencil GL_EXT_packed_float GL_EXT_packed_pixels GL_EXT_pixel_buffer_object GL_EXT_point_parameters GL_EXT_provoking_vertex GL_EXT_rescale_normal GL_EXT_secondary_color GL_EXT_separate_specular_color GL_EXT_shader_image_load_store GL_EXT_shadow_funcs GL_EXT_stencil_wrap GL_EXT_subtexture GL_EXT_texgen_reflection GL_EXT_texture3D GL_EXT_texture_array GL_EXT_texture_buffer_object GL_EXT_texture_compression_bptc GL_EXT_texture_compression_latc GL_EXT_texture_compression_rgtc GL_EXT_texture_compression_s3tc GL_EXT_texture_cube_map GL_EXT_texture_edge_clamp GL_EXT_texture_env_add GL_EXT_texture_env_combine GL_EXT_texture_env_dot3 GL_EXT_texture_filter_anisotropic GL_EXT_texture_integer GL_EXT_texture_lod GL_EXT_texture_lod_bias GL_EXT_texture_mirror_clamp GL_EXT_texture_object GL_EXT_texture_rectangle GL_EXT_texture_sRGB GL_EXT_texture_shared_exponent GL_EXT_texture_snorm GL_EXT_texture_swizzle GL_EXT_timer_query GL_EXT_transform_feedback GL_EXT_vertex_array GL_EXT_vertex_array_bgra GL_EXT_vertex_attrib_64bit GL_IBM_texture_mirrored_repeat GL_KTX_buffer_region GL_NV_blend_square GL_NV_conditional_render GL_NV_copy_depth_to_color GL_NV_explicit_multisample GL_NV_float_buffer GL_NV_half_float GL_NV_primitive_restart GL_NV_texgen_reflection GL_NV_texture_barrier GL_SGIS_generate_mipmap GL_SGIS_texture_edge_clamp GL_SGIS_texture_lod GL_SUN_multi_draw_arrays GL_WIN_swap_hint WGL_EXT_swap_control
wgl extensions=WGL_ARB_extensions_string WGL_ARB_pixel_format WGL_ATI_pixel_format_float WGL_ARB_pixel_format_float WGL_ARB_multisample WGL_EXT_swap_control WGL_ARB_pbuffer WGL_ARB_render_texture WGL_ARB_make_current_read WGL_EXT_extensions_string WGL_ARB_buffer_region WGL_EXT_framebuffer_sRGB WGL_ATI_render_texture_rectangle WGL_EXT_pixel_format_packed_float WGL_I3D_genlock WGL_NV_swap_group WGL_ARB_create_context WGL_AMD_gpu_association WGL_AMDX_gpu_association WGL_ARB_create_context_profile WGL_NV_float_buffer
gl: extensions=(multitexture) (framebuffer) (separate color) (anisotropic filter of 16.00) (compressed texture) (cubemaps) (shader objects)
wgl: extensions=(wglpixelformat) (swapcontrol) (multisample)
gl: reducing max texture size from 16384 to 2048
tmsystem: fullscreen modes=(rj-640x480x16x60) (rj-640x480x32x60) (800x600x16x60) (1024x768x16x60) (1280x720x16x60) (1280x768x16x60) (1280x800x16x60) (1280x960x16x60) (1280x1024x16x60) (1360x768x16x60) (1400x1050x16x60) (1440x900x16x60) (1600x1200x16x60) (1680x1050x16x60) (1920x1080x16x60) (1920x1200x16x60)
tmsystem: opengl samples buffers=2
directinput: searching joysticks=(0(6 axis 6 button joystick): 6 axes, 6 buttons)
(61::Vertex shader was successfully compiled to run on hardware.
) (63::Fragment shader was successfully compiled to run on hardware.
) (25rogramobject:Validation successful.
framebuffer object created (512, 512)
framebuffer object created (256, 256)
tminput: searching for input devices...(3)
tmsystem: searching usb interface (0) 0=radiointerface
tmsystem: searching usb interface (1) 1=unable to open interface device
tmsystem: searching usb interface (0) 1=unable to open joystick device
tmsystem: searching usb interface (1) 1=unable to open joystick device
tmsystem: searching dummy usb interface (0) 1=unable to open interface device
tmsystem: searching dummy usb interface (0) 1=unable to open joystick device
tminput: checking for joystick 0=6 axes 6 buttons
tminput: 2 devices found
sim: loading scenery scenery/winzeln.geo...
sim: 1 objects 0 dynobjects
sim: start position 1 (not for helicopter)
sim: start position 2 (not for helicopter)
sim: start position 3 (not for helicopter)
sim: start position 4 (not for airplanes)
sim: load texture grid 5x5 (pano=0) (compress=1) named winzeln/winzeln=(3.600x4.000) (5x5) (20x10)
sim: sphere params(0)=-1.5000 0.0000 -0.7000
sim: loading ground object scenery/winzeln/winzeln.obj=ok
sim: loading time=65156 mus
sim: 1 photo scenes
tmcollision: 1604 triangles using 205312 bytes
tmcollision: omin=(-5000.0,-5000.0,-2.1) omax=(5000.0,5000.0,59.6) octmin=(40.0,40.0,40.0)
tmcollision: otnodes=73 otendnodes=37 otdepth=17 otlistareas=25349
tmcollision: otnmaxareas=219 otnavgareas=57 otnminsize=(39.063,39.063,30.883)
tmcollision: otareas=2124 mem=213808
tmcollision: 73 octrees, using 11096 bytes
tmcollision: total mem=224904 bytes
tmcollision: time=0.01s
tmcolldynamic: no dynamic objects or triangles
sim: loading aircraft 1 su31...
tmdairfoil: loading naca0015 ok
openal: register sound sound/g15-3000.wav=(12, rd=4.73) ok
openal: register sound sound/g15-5000.wav=(13, rd=4.73) ok
openal: register sound sound/g15-10000.wav=(14, rd=4.73) ok
generating shadow 0=radius=2.71 bbmin=(-1.59 -1.59 -0.45) bbmax=(1.59 1.59 0.41)
sim: creating blurr=Propeller
loading input device calibration config/radio0.tmc=ok
loading input device calibration config/joystick0.tmc=ok
tmmusic: play random songs
tmsystem: calibrating radio deviations= 0 3 6 9 -16 25 (timer=39995) -36 4) 88 (4ABDE644)
directinput: shutting down joystick 0 (6 axis 6 button joystick)
openal: shutdown=ok
directinput: shutdown
saving configfile config/main.mcf=ok
saving player configfile config/player1.mcf=ok
tmsystem: 0 memory blocks:
tmsystem: shutdown, 0 memory blocks left using 0 bytes
Tm.log end -
dbrickma is offline
Old 01-14-2011, 06:39 PM
rajul
rajul's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: AFDP display problem with Radeon 5770
Hi Don, a few questions. What's the native resolution of your monitor? Did you uninstall the previous ATI driver before installing the new 10.12 driver? When you upgraded your system, did you reinstall windows?
rajul is online now
Old 01-15-2011, 08:32 AM
dbrickma
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi Mike,
Thanks for the quick reply. I forgot to mention at the outset that AFPD runs fine in a window... it's only full-screen that has problems. And I tried several other full-screen resolutions; they all had the problem.
This was an all-new system with a clean Windows 7 install. The monitor has a native 1920x1200 resolution. And no, I didn't uninstall the previous ATI driver, I just ran the Catalyst 10.12 download. I didn't mention that I had the same problem with the previous ATI driver version... in fact that's why I installed the latest. Also, I have a copy of FSOne (original version) that I installed as a test. It has problems too.
Don
dbrickma is offline
Old 01-15-2011, 08:42 AM
rajul
rajul's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Don, try the following:
1. Go to the config directory of AFPD, by default this is at c:\program files\ipacs\aerofly professional deluxe\config
2. Make a backup of the file main.mcf
3. Open main.mcf with a simple text editor like notepad or word
4. Look for the first 3 lines and change them to:
window_width 1298
window_height 811
window_fullscreen 1
rajul is online now
Old 01-15-2011, 09:04 AM
dbrickma
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi Mike,
Tried the change to main.mcf. AFPD ended up in windowed mode.
BTW I was looking at the Window system logs and found the ACEEventLog created by ATI/Catalyst. Any use?
Don
dbrickma is offline
Old 01-15-2011, 09:21 AM
rajul
rajul's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Please change the numbers to:
window_width 1920
window_height 1200
window_fullscreen 1
You could adjust the width and height until the window fits the screen
rajul is online now
Old 01-16-2011, 07:49 AM
dbrickma
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi Mike,
You're right, windowed "full-screen" is quite usable. Any idea if Aerofly 5 has the same problem???
Don
dbrickma is offline
Old 01-16-2011, 07:55 AM
rajul
rajul's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
This could be some videocard driver compatibility issue with your system and I rarely see it. However, you can use the mcf file to force the window size and it's not really a problem anymore. I am running AFPD and AF5 about the same system config as yours without a similar "problem". On the AF5 running in your system, you could also use the mcf file if you face a similar issue.
rajul is online now
Old 01-16-2011, 08:13 AM
dbrickma
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks, Mike
dbrickma is offline
Reply
Display Modes
