Ikarus Aerofly flight simulators Get the answers to your technical questions about Ikarus' Aerofly flight simulators here in their official support forum
Have Dx6i hooked up and working, but have questions
Reply
Old 04-05-2011, 04:17 AM
Eddie nyc
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Have Dx6i hooked up and working, but have questions
So I have the throttle hold and stunt mode working along with the rest of it seemingly. Took a bit, but the instructions here were helpful.
My question is that when I was flying it last night, I just pulled up a model I had saved for my Blade mCPx. In that model, i have settings for Dual Rates and Expo. How does aerofly recognize dual rates (or travel adj) and expo? Is it just what is typed into the program's control panel, or does it read it from the Tx when I flip the switch. I don't know if it tries to read one or both.
Also is the program's setting a dual rate or a travel adjustment? I think it's recognizing the pitch and throttle curves, but not sure about this other stuff.
Thanks.
Eddie nyc is offline
Old 04-05-2011, 04:43 AM
rajul
Moderator
My Feedback: (58)
rajul's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Have Dx6i hooked up and working, but have questions
You have to set dual rate and expo in your programmable radio. Please check your radio manual on how to do this. For the dual rate switch, always calibrate the radio in Aerofly with the switch in high rate position, not low rate.
rajul is offline
Old 04-05-2011, 05:23 AM
Eddie nyc
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Ok thanks. The model I've been using has Dual Rates and expo factored into it. So I guess I just leave the aerofly settings at 100 and 0 then right?
Old 04-05-2011, 05:25 AM
rajul
Moderator
My Feedback: (58)
rajul's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I would recommend to use your programmable radio functions to the fullest. In that way, you get a feel for the radio like in the field
rajul is offline
Old 04-06-2011, 04:56 AM
Eddie nyc
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: rajul
Got it set up that way now and it seems to work well. Thanks! No I just need to find a good source for learning some basic aerobatic and 3D moves (i.e., do this and this with the sticks to perform a roll or to go inverted for a hover).
