Aurora 9
AZ
Aurora 9
Hello,
I recently purchased Aerofly 5 for my new 27" monitor. I am able to get the software to run and was able to calibrate my Aurora 9 for the main control surfaces. However, none of my switches or sliders will calibrate. I would like the ability to use dual or triple rates that I would normally use when flying. Any help you can provide would be greatly appreciated.
Geoff
Geoff
Moderator
My Feedback: (58)
RE: Aurora 9
Geoff, I would suggest that you read through the manual first especially chapters 5 (Calibration), 10.2 (Model Functions) and 13.1 (Advanced Channels Setup). The easiest way to setup and assign your switches is by using "Calibrate and Configure". You could also use "Assign Model Functions" and this will only let you assign switches for the functions available for the particular model. As you get more experienced, you can assign all channels using "Advanced Channels Setup".
To get dual/triple rates for any control surface, put the rate switch to high rate, and calibrate the stick at high rate.
AZ
RE: Aurora 9
I was able to get dual rates smoke and retracts to work. For some reason the software still won't recognize my 3 way switch. Still a great sim just wish it included gridlines for practicing straight and level flight.
