Aerofly Pro Deluxe and JR 11x Problems
I've successfully used Aerofly Pro Deluxe on my Futaba 12FG radio. Sold the radio and now using a JR 11X.
The software does not recognize the tx "Aerofly pro has located the USB interface cable, but was unable to either find a transmitter connected to the USB interface or..."
I am plugging into the Ikarus USB adapter using the 3wire JR style connector (brown wire going to the outside of the USB Adapter) then into the jack plugged into the back of the tx.
I am SLAVE mode (in the Trainer menu). Although I tried MASTER too. Nothing works.
Tell me what I am doing wrong.
Thanks in advance.
- Rob
Thanks in advance.
- Rob
My Feedback: (58)
Rob, is your radio in PPM mode? Please also post a photo of the cable connections from your computer to the radio. Thanks
My Feedback: (58)
You will also need to disable the trainer mode
OK - I put it back to Master mode and same problem. I attached a pic of the wire setup.
I don't know how to put it in PPM mode. I looked through the manual for the 11X and it was no help either. It appears to be in DSM mode.
Suggestions.
Suggestions.
My Feedback: (58)
Thanks for the photo. It looks like what you're missing is the JR adapter cable that goes between the radio and the usb interface cable. Your connection should follow the attached diagram.
that worked! Thanks so much!
My Feedback: (58)
Enjoy!
IL
Delete question
FL
Hi Rajul,
I received my AF5 and was abñe to installed in my Mac, but it can recognizes my JR X9503 or XP7202. I saw your answer about the JR adapter that you suggested. It was not included in my box. Is this right? how can I get it ?
I appreciate your help !
Luis
Luis
My Feedback: (58)
Luis, please read the forum rules before posting in any thread
Previous Thread
Next Thread
