Ikarus Aerofly flight simulators Get the answers to your technical questions about Ikarus' Aerofly flight simulators here in their official support forum
Aerofly 5.7 coming soon!
Reply
Old 10-14-2011, 07:59 AM
rajul
rajul's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Aerofly 5.7 coming soon!
Looks like the next free upgrade Aerofly 5.7 will be coming soon. At the moment, there's only some info in German http://www.ipacs.de/forum/showthread...en-zum-neuen-a You could use an online webpage translator like AltaVista. The new TrackIR feature is certainly interesting! I will release more info as soon as it is available.
rajul is offline
Old 11-02-2011, 04:14 PM
matus777
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Aerofly 5.7 coming soon!
Just downloaded the 5.7.1001 update for the MAC and it's really running slow compared to the pre-update version....29 FPS now....if i really dummy it down i can get 60 in the air with no scenery visible.....any suggestions would be helpful....thanks!
matus777 is offline
Old 11-03-2011, 04:54 AM
rajul
rajul's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
matus, 5.7 should perform the same. Try going into the quality setting and set everything to MEDIUM as a starting point. Did you disable VSYNC?
Could you provide some details on your system, i.e. mac OS, RAM size, video card, and driver version?
rajul is offline
Old 11-03-2011, 05:18 AM
matus777
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Yes, vertical synch is off and it seems worse on the medium settings than when high is selected....29fps vs 49 fps....system data below:
Also glare is off, music off etc.
Model Name: iMac
Model Identifier: iMac11,3
Processor Name: Intel Core i3
Processor Speed: 3.2 GHz
Number Of Processors: 1
Total Number Of Cores: 2
L2 Cache (per core): 256 KB
L3 Cache: 4 MB
Memory: 4 GB
Processor Interconnect Speed: 5.86 GT/s
Boot ROM Version: IM112.0057.B00
SMC Version (system): 1.59f2
Serial Number (system): QP038063DNP
Hardware UUID: 4557250C-16BC-5614-83FE-A9B902673D81
matus777 is offline
Old 11-03-2011, 05:31 AM
rajul
rajul's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
matus, what type of video card do you have?
rajul is offline
Old 11-03-2011, 05:40 AM
matus777
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ATI Radeon HD 5670:
Chipset Model: ATI Radeon HD 5670
Type: GPU
Bus: PCIe
PCIe Lane Width: x16
VRAM (Total): 512 MB
Vendor: ATI (0x1002)
Device ID: 0x68c0
Revision ID: 0x0000
ROM Revision: 113-B9850K-133
EFI Driver Version: 01.00.416
Displays:
iMac:
Resolution: 2560 x 1440
Pixel Depth: 32-Bit Color (ARGB8888)
Main Display: Yes
Mirror: Off
Online: Yes
Built-In: Yes
Connection Type: DisplayPort
Display Connector:
Status: No Display Connected
Also before i operate AF5 i shut down all other programs.........i noticed that this seems to help performance as well both before and now but it still is not like before the update? Thanks.
Also can you explain what "Track IR" is?
matus777 is offline
Old 11-03-2011, 05:51 AM
rajul
rajul's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Matus,
Which OS version are you using?
What scenery, cloud settings, and resolution?
rajul is offline
Old 11-03-2011, 05:58 AM
matus777
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
OS X 10.6.8 medium resolution, cloud box checked, and the Heriden (sp) site
matus777 is offline
Old 11-03-2011, 06:08 AM
matus777
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
2560x1440 on monitor display if this helps?
matus777 is offline
Old 11-03-2011, 06:24 AM
rajul
rajul's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Could you copy and paste the entire content of your tmlog file which you can find in the main directory. Right click on it and use textedit
rajul is offline
Old 11-03-2011, 06:33 AM
matus777
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
tmmodule: (5 modules) (tmatmosphere,1) (tmsystimer,1) (tmrandom,2) (tmfile,4) (tmopenal,20)
tmmodule: init modules=(tmrandom=(seed=466507980) ok) done
macosx-cocoa: Program version 5.7.1.1
macosx-cocoa: Library Version 5.7, Copyright (C) 1998-2011, IPACS
macosx-cocoa: http://www.ipacs.de
macosx-cocoa: cpu speed = 3200 Mhz type=573b5eec
macosx-cocoa: mac os version=1068 (10.6.8) (logical mem=2047MB) (physical mem=2047MB)
tmfile: loading tmfile 'config/main.mcf' = (4803 bytes) done
tmopenal: init= (default=Built-in Output) (0:Built-in Output) (version=1.1) (1.1) ok
macosx-cocoa: gl: vendor=ATI Technologies Inc., renderer=ATI Radeon HD 5670 OpenGL Engine, version=2.1 ATI-1.6.36
macosx-cocoa: (version=2.1) (compatibility profile)
macosx-cocoa: gl: (viewport=16384x16384) (texturesize=8192)
macosx-cocoa: gl: extensions=GL_ARB_transpose_matrix GL_ARB_vertex_program GL_ARB_vertex_blend GL_ARB_window_pos GL_ARB_shader_objects GL_ARB_vertex_shader GL_ARB_shading_language_100 GL_EXT_multi_draw_arrays GL_EXT_clip_volume_hint GL_EXT_rescale_normal GL_EXT_draw_range_elements GL_EXT_fog_coord GL_EXT_gpu_program_parameters GL_EXT_geometry_shader4 GL_EXT_transform_feedback GL_APPLE_client_storage GL_APPLE_specular_vector GL_APPLE_transform_hint GL_APPLE_packed_pixels GL_APPLE_fence GL_APPLE_vertex_array_object GL_APPLE_vertex_program_evaluators GL_APPLE_element_array GL_APPLE_flush_render GL_APPLE_aux_depth_stencil GL_NV_texgen_reflection GL_NV_light_max_exponent GL_IBM_rasterpos_clip GL_SGIS_generate_mipmap GL_ARB_imaging GL_ARB_point_parameters GL_ARB_texture_env_crossbar GL_ARB_texture_border_clamp GL_ARB_multitexture GL_ARB_texture_env_add GL_ARB_texture_cube_map GL_ARB_texture_env_dot3 GL_ARB_multisample GL_ARB_texture_env_combine GL_ARB_texture_compression GL_ARB_texture_mirrored_repeat GL_ARB_shadow GL_ARB_depth_texture GL_ARB_shadow_ambient GL_ARB_fragment_program GL_ARB_fragment_program_shadow GL_ARB_fragment_shader GL_ARB_occlusion_query GL_ARB_point_sprite GL_ARB_texture_non_power_of_two GL_ARB_vertex_buffer_object GL_ARB_pixel_buffer_object GL_ARB_draw_buffers GL_ARB_shader_texture_lod GL_ARB_color_buffer_float GL_ARB_half_float_vertex GL_ARB_texture_rg GL_ARB_texture_compression_rgtc GL_ARB_framebuffer_object GL_EXT_compiled_vertex_array GL_EXT_draw_buffers2 GL_EXT_framebuffer_object GL_EXT_framebuffer_blit GL_EXT_framebuffer_multisample GL_EXT_texture_rectangle GL_ARB_texture_rectangle GL_EXT_texture_env_add GL_EXT_blend_color GL_EXT_blend_minmax GL_EXT_blend_subtract GL_EXT_texture_lod_bias GL_EXT_abgr GL_EXT_bgra GL_EXT_stencil_wrap GL_EXT_texture_filter_anisotropic GL_EXT_separate_specular_color GL_EXT_secondary_color GL_EXT_blend_func_separate GL_EXT_shadow_funcs GL_EXT_stencil_two_side GL_EXT_texture_compression_s3tc GL_EXT_texture_compression_dxt1 GL_EXT_texture_sRGB GL_EXT_blend_equation_separate GL_EXT_texture_mirror_clamp GL_EXT_packed_depth_stencil GL_EXT_bindable_uniform GL_EXT_texture_integer GL_EXT_gpu_shader4 GL_EXT_framebuffer_sRGB GL_EXT_provoking_vertex GL_APPLE_flush_buffer_range GL_APPLE_ycbcr_422 GL_APPLE_rgb_422 GL_APPLE_vertex_array_range GL_APPLE_texture_range GL_APPLE_float_pixels GL_ATI_texture_float GL_ARB_texture_float GL_ARB_half_float_pixel GL_APPLE_pixel_buffer GL_APPLE_object_purgeable GL_NV_blend_square GL_NV_fog_distance GL_NV_conditional_render GL_ATI_texture_mirror_once GL_ATI_blend_equation_separate GL_ATI_blend_weighted_minmax GL_ATI_texture_env_combine3 GL_ATI_separate_stencil GL_ATI_texture_compression_3dc GL_SGIS_texture_edge_clamp GL_SGIS_texture_lod GL_SGI_color_matrix GL_EXT_texture_array GL_EXT_vertex_array_bgra GL_ARB_instanced_arrays GL_ARB_depth_buffer_float GL_EXT_packed_float GL_EXT_texture_shared_exponent
macosx-cocoa: gl: extensions=(anisotropic filter of 16.00) (gpu shader 4)
sim:
sim: FUNC RenderOpen BEGIN
sim:
tmxgltext: loading font (0) 'texture/fontbig.tff'=(512x256) (h=26) (nc=256) ok
tmxgltext: loading font (1) 'texture/fontbig.tff'=(512x256) (h=26) (nc=256) ok
tmxgltext: loading font (2) 'texture/console.tff'=(256x128) (h=15) (nc=256) ok
tmxgltext: loading font (3) 'texture/font.tff'=(2048x2048) (h=17) (nc=65535) ok
tminput: searching for input devices...(3)
macosx-inputdeviceusb: searching usb interface (0,0)=(radiointerface) 3d1d4871
tminput: 1 devices found= (USB Interface #1) (3d1d4871)
tmmusic: (11 mp3 files found) (playlist = 0 songs)off
sim: loading scenery 'scenery//herrieden'...
tmscene: (8x8) (29x14) (r=5000.00) (sp=0.00 0.00 -8.34) (vp=0.00 0.00 1.66) (ambient=0.09 0.11 0.16) (diffuse=1.00 1.00 0.98) (sphereambient=0.22 0.20 0.20)
tm_scenery_extras: found runway Asphalt
tm_scenery_extras: found corners: -36.05 -14.33 0.45, -34.14 -27.34 0.46, 43.00 -10.32 -0.27, 39.33 1.88 -0.17,
tm_scenery_extras: found pivots: -23.06 -18.46 0.28, 26.42 -7.39 0.09,
tm_scenery_extras: found directions: 0.98 0.22 0.00, -0.98 -0.22 0.00,
tmxgltext: 82 textures using 42 MB
tmcollision: init = (tris=35654, 7416032 bytes) (-2369.58 -2444.63 -31.27 - 2399.14 2324.08 46.68) (time=0.08s)
tmcollision: (199 input objects) (1 base objects) (1 instance objects) (0 dynamic objects) (time=0.00s)
tmfile: loading tmfile 'config/scenery-herrieden.tmc' = (873 bytes) done
tmcollision: creating static collisionobjects quadtree = (objects=1) (-2369.59 -2444.64 -31.28) - (2399.15 2324.09 46.69)
tmscene: scene bounding box = (-2369.58 -2444.63 -31.27) (2399.14 2324.08 46.68)
tmscene: max objects per cell = 77
tmscene: shadowmap = 2048x2048 sp=4 (10.00 43.00 185.50 800.00 0.00 0.00 0.00)
sim: done loading scenery (t=0.45s objects=132)
sim:
sim: windfieldinfo 0: resolution=2.00 min=(-500.00 -500.00 0.00) max=(500.00 500.00 100.00)
tmwindfield: Setup Windfield with origin = (-500.0, -500.0, 0.0), size_xy = (1000.0m, 1000.0m), Grid relation (x:y): 1:1, MipMapLevels: 9, Resolution: (2.0m, 2.0m)
tmwindfield: Windfield Map Load from file 'scenery/herrieden/windfield0.twd' successful
tmscene: statistics = (objects=143) (transparent=0) (graphics=11) (graphicsbb=0) (dynamic=0) (decals=0) (water=0) (tris=0) (shadow faces=0) (btrees=0) (trees=0)
tmfile: loading tmfile 'config/player0.mcf' = (2331 bytes) done
sim: loading model 'extra260'...
sim: path='aircraft/extra260' geometry='extra260' physics='extra260__000' paintscheme='' ...
tmmodelmanager: assigning controller to receiver
tmmodelmanager: model input channel Throttle Aileron Elevator Rudder Smoke
sim: done loading model (t=0.29s, n=67, id=10)
sim:
tmfile: loading tmfile 'config/player1.mcf' = (2313 bytes) done
tmfile: loading tmfile 'menu/settings.mcf' = (97683 bytes) done
tmmodelmanager: (0:airfoil) (1:airfoil) (2:airfoil) (3:airfoil) (4:airfoil) (5:airfoil)
tmmodelmanager: (6:airfoil) (7:airfoil) (8:airfoil) (9:airfoil) (10:airfoil) (11:airfoil) (12:airfoil) loading tmfile 'config/rc0-3d1d4871.tmc' = (73452 bytes) done
sim_update: connecting to server www.aerofly.com= FAIL(-13,43)
tmxgltext: 402 textures using 98 MB
sim:
sim: FUNC RenderOpen END = 3.218621 sec
sim:
macosx-cocoa: compute thread started
tm: calibrating radio deviations= 0 3 6 9 -16 25 -36 88
license: license: tml file 'af5-c010.tml' = C010 0000 0507 0101 'aerofly5' 'C010-3D1D4871.lic' (activated=1)
macosx-cocoa: compute thread exited
sim: FUNC Shutdown
matus777 is offline
Old 11-03-2011, 07:25 AM
rajul
rajul's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
matus, what is the exact resolution in AF5? Are you using fullscreen mode or windows?
rajul is offline
Old 11-03-2011, 08:34 AM
matus777
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Full screen with Medium selected all choices.....is this what you mean as far as resolution?
matus777 is offline
Old 11-03-2011, 12:26 PM
matus777
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Several additional observations Raul. With medium selected for AF5 resolution the scenery develops a visual wave from ground to top of trees when plane is flying along side them, the planes appears to actually go thru the clouds (plane actually becomes milky) when flying by them(the clouds) and for the 1st time while using AF5 my Mac went into the screen saver mode after about 6 minutes of use....black screen for a few seconds then screen saver?
matus777 is offline
Old 11-03-2011, 10:05 PM
rajul
rajul's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: matus777
No, check the resolution box just at the right side of the full screen/window selection e.g. 1920x1080 60Hz etc. Then select the same resolution for your monitor
rajul is offline
Old 11-04-2011, 04:47 AM
matus777
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
OK....where is the resolution box? Is it in the AF5 program? If so i can't locate it for some reason?
What i did to make the program more useable was to limit field of view and autozoom & reduce height dependent vertical camera.....it flyable now but not the same as before.
Can you provide steps for getting to the resolution box...thanks?
Also can you provide info as to what the "TrackIR feature " is?
matus777 is offline
Old 11-04-2011, 05:05 AM
rajul
rajul's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Go to simulation->graphics settings
rajul is offline
Old 11-04-2011, 05:13 AM
matus777
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I don't have that option now....all i have are percentages....i'll attach a screen shot.
matus777 is offline
Old 11-04-2011, 05:14 AM
matus777
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
screen shot did not up load?
matus777 is offline
Old 11-04-2011, 05:19 AM
matus777
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Try this....
ID:	1682228   Click image for larger version
matus777 is offline
Old 11-04-2011, 06:25 AM
rajul
rajul's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
What % are you using for the screen resolution?
Please do the following:
- load pt40 model
- load us bennetfield scenery
- set quality for all things to MEDIUM
What FPS are you getting?
rajul is offline
Old 11-04-2011, 08:08 AM
matus777
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Set to 100% & medium as requested i'm showing 69FPS with the PT40 sitting on the runway....
matus777 is offline
Old 11-04-2011, 08:18 AM
matus777
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
...and the AF5 program still goes into my screen saver mode after a period of time while in use and actively flying??????
matus777 is offline
Old 11-05-2011, 05:04 AM
rajul
rajul's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
matus, please install the old version of AF5 from your main disk to anywhere on your harddisk for comparison. The installation steps are as below:
1) double click on the DMG file on the dvd
2) in the then opening window drag the aerofly5 folder to the desktop or any folder.
3) run the old version AF5 and again
- load pt40 model
- set to fullscreen at 100%
rajul is offline
Old 11-05-2011, 02:31 PM
matus777
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I attempted to do what i think you requested and was unable....included are the screen shots?????
ID:	1682680   Click image for larger version
matus777 is offline
Reply
Display Modes
