Aerofly 5.7.1.1
NY
Aerofly 5.7.1.1
Raj,
I am running bootcamp with my macbook pro, 2010, geforce 9600m, with 8gig ram.
I installed 5.5 and upgraded to 5.7
My fps were initially 130-150
After the upgrade to 5.7, it went down to 20 fps.
I unloaded some start up items, and Iwas able to get it in the 100 range.
After a crash, the fps go down to 70.
After another crash, the fps go down to 40.
I know, I should not crash.
But it seems the program crashes when after I crash.
Suggestions please.
Thanks in advance.
Suggestions please.
Thanks in advance.
NY
RE: Aerofly 5.7.1.1
tmmodule: (7 modules) (tmatmosphere,1) (tmsystimer,1) (tmrandom,2) (tmfile,4) (tmwinjoystick,10) (tmwinogl,10) (tmopenal,20)
tmmodule: init modules=(tmsystimer=ok) (tmrandom=(seed=566612903) ok) done
tmsyswin: Program version 5.7.1.1
tmsyswin: Library Version 5.6, Copyright (C) 1999-2011, IPACS
tmsyswin: http://www.ipacs.de
tmsyswin: memory=(physical=8167MB, avail=0MB) (virtual=7225MB, avail=0MB) (16333 in use)
tmsyswin: operating system=Microsoft Windows 7 Version 6.1 Service Pack 1 (Build 7601) Service Pack: Service Pack 1 (Build 7601)
tmfile: loading tmfile 'config/main.mcf' = (4762 bytes) done
tmsyswin: fullscreen modes=(1152x864x32x60) (1280x768x32x60) (1280x800x32x60) (1360x768x32x60) (1366x768x32x60) (1440x900x16x60)
tmsyswin: init window=(mdf=60Hz) (window=0x0x1376x768) (client=1376x768) (screen=1440x900) (32bpp) (60Hz) (windowed mode)
tmwinogl: initializing opengl= (samplebuffers=0) (colorbits=32) (stencilbits=0) (depthbits=0)
tmwinogl: (compiling test shader= ok) (version=3.3) (compatibility profile) (vendor=NVIDIA Corporation) (renderer=GeForce 9600M GT/PCI/SSE2) (version=3.3.0)
tmwinogl: opengl caps=(viewport=8192x8192) (texsize=8192) (texsize3d=0) (stencil=96) (texunits=32) (ps-texunits=0) (shading_language=3.30 NVIDIA via Cg compiler) (shader_max_vertex=4096) (shader_max_fragment=2048)
tmwinogl: gl extensions=GL_ARB_base_instance GL_ARB_blend_func_extended GL_ARB_color_buffer_float GL_ARB_compatibility GL_ARB_compressed_texture_pixel_storage GL_ARB_conservative_depth GL_ARB_copy_buffer GL_ARB_depth_buffer_float GL_ARB_depth_clamp GL_ARB_depth_texture GL_ARB_draw_buffers GL_ARB_draw_elements_base_vertex GL_ARB_draw_instanced GL_ARB_ES2_compatibility GL_ARB_explicit_attrib_location GL_ARB_fragment_coord_conventions GL_ARB_fragment_program GL_ARB_fragment_program_shadow GL_ARB_fragment_shader GL_ARB_framebuffer_object GL_ARB_framebuffer_sRGB GL_ARB_geometry_shader4 GL_ARB_get_program_binary GL_ARB_half_float_pixel GL_ARB_half_float_vertex GL_ARB_imaging GL_ARB_instanced_arrays GL_ARB_internalformat_query GL_ARB_map_buffer_alignment GL_ARB_map_buffer_range GL_ARB_multisample GL_ARB_multitexture GL_ARB_occlusion_query GL_ARB_occlusion_query2 GL_ARB_pixel_buffer_object GL_ARB_point_parameters GL_ARB_point_sprite GL_ARB_provoking_vertex GL_ARB_robustness GL_ARB_sampler_objects GL_ARB_seamless_cube_map GL_ARB_separate_shader_objects GL_ARB_shader_bit_encoding GL_ARB_shader_objects GL_ARB_shading_language_100 GL_ARB_shading_language_420pack GL_ARB_shading_language_include GL_ARB_shading_language_packing GL_ARB_shadow GL_ARB_sync GL_ARB_texture_border_clamp GL_ARB_texture_buffer_object GL_ARB_texture_compression GL_ARB_texture_compression_rgtc GL_ARB_texture_cube_map GL_ARB_texture_env_add GL_ARB_texture_env_combine GL_ARB_texture_env_crossbar GL_ARB_texture_env_dot3 GL_ARB_texture_float GL_ARB_texture_mirrored_repeat GL_ARB_texture_multisample GL_ARB_texture_non_power_of_two GL_ARB_texture_rectangle GL_ARB_texture_rg GL_ARB_texture_rgb10_a2ui GL_ARB_texture_storage GL_ARB_texture_swizzle GL_ARB_timer_query GL_ARB_transpose_matrix GL_ARB_uniform_buffer_object GL_ARB_vertex_array_bgra GL_ARB_vertex_array_object GL_ARB_vertex_buffer_object GL_ARB_vertex_program GL_ARB_vertex_shader GL_ARB_vertex_type_2_10_10_10_rev GL_ARB_viewport_array GL_ARB_window_pos GL_ATI_draw_buffers GL_ATI_texture_float GL_ATI_texture_mirror_once GL_S3_s3tc GL_EXT_texture_env_add GL_EXT_abgr GL_EXT_bgra GL_EXT_bindable_uniform GL_EXT_blend_color GL_EXT_blend_equation_separate GL_EXT_blend_func_separate GL_EXT_blend_minmax GL_EXT_blend_subtract GL_EXT_compiled_vertex_array GL_EXT_Cg_shader GL_EXT_depth_bounds_test GL_EXT_direct_state_access GL_EXT_draw_buffers2 GL_EXT_draw_instanced GL_EXT_draw_range_elements GL_EXT_fog_coord GL_EXT_framebuffer_blit GL_EXT_framebuffer_multisample GL_EXTX_framebuffer_mixed_formats GL_EXT_framebuffer_object GL_EXT_framebuffer_sRGB GL_EXT_geometry_shader4 GL_EXT_gpu_program_parameters GL_EXT_gpu_shader4 GL_EXT_multi_draw_arrays GL_EXT_packed_depth_stencil GL_EXT_packed_float GL_EXT_packed_pixels GL_EXT_pixel_buffer_object GL_EXT_point_parameters GL_EXT_provoking_vertex GL_EXT_rescale_normal GL_EXT_secondary_color GL_EXT_separate_shader_objects GL_EXT_separate_specular_color GL_EXT_shadow_funcs GL_EXT_stencil_two_side GL_EXT_stencil_wrap GL_EXT_texture3D GL_EXT_texture_array GL_EXT_texture_buffer_object GL_EXT_texture_compression_dxt1 GL_EXT_texture_compression_latc GL_EXT_texture_compression_rgtc GL_EXT_texture_compression_s3tc GL_EXT_texture_cube_map GL_EXT_texture_edge_clamp GL_EXT_texture_env_combine GL_EXT_texture_env_dot3 GL_EXT_texture_filter_anisotropic GL_EXT_texture_format_BGRA8888 GL_EXT_texture_integer GL_EXT_texture_lod GL_EXT_texture_lod_bias GL_EXT_texture_mirror_clamp GL_EXT_texture_object GL_EXT_texture_shared_exponent GL_EXT_texture_sRGB GL_EXT_texture_sRGB_decode GL_EXT_texture_storage GL_EXT_texture_swizzle GL_EXT_texture_type_2_10_10_10_REV GL_EXT_timer_query GL_EXT_vertex_array GL_EXT_vertex_array_bgra GL_EXT_import_sync_object GL_IBM_rasterpos_clip GL_IBM_texture_mirrored_repeat GL_KTX_buffer_region GL_NV_alpha_test GL_NV_blend_minmax GL_NV_blend_square GL_NV_complex_primitives GL_NV_conditional_render GL_NV_copy_depth_to_color GL_NV_copy_image GL_NV_depth_buffer_float GL_NV_depth_clamp GL_NV_explicit_multisample GL_NV_fbo_color_attachments GL_NV_fence GL_NV_float_buffer GL_NV_fog_distance GL_NV_fragdepth GL_NV_fragment_program GL_NV_fragment_program_option GL_NV_fragment_program2 GL_NV_framebuffer_multisample_coverage GL_NV_geometry_shader4 GL_NV_gpu_program4 GL_NV_half_float GL_NV_light_max_exponent GL_NV_multisample_coverage GL_NV_multisample_filter_hint GL_NV_occlusion_query GL_NV_packed_depth_stencil GL_NV_parameter_buffer_object GL_NV_parameter_buffer_object2 GL_NV_path_rendering GL_NV_pixel_data_range GL_NV_point_sprite GL_NV_primitive_restart GL_NV_register_combiners GL_NV_register_combiners2 GL_NV_shader_buffer_load GL_NV_texgen_reflection GL_NV_texture_barrier GL_NV_texture_compression_vtc GL_NV_texture_env_combine4 GL_NV_texture_expand_normal GL_NV_texture_lod_clamp GL_NV_texture_multisample GL_NV_texture_rectangle GL_NV_texture_shader GL_NV_texture_shader2 GL_NV_texture_shader3 GL_NV_transform_feedback GL_NV_vertex_array_range GL_NV_vertex_array_range2 GL_NV_vertex_buffer_unified_memory GL_NV_vertex_program GL_NV_vertex_program1_1 GL_NV_vertex_program2 GL_NV_vertex_program2_option GL_NV_vertex_program3 GL_NVX_conditional_render GL_NVX_gpu_memory_info GL_OES_depth24 GL_OES_depth32 GL_OES_depth_texture GL_OES_element_index_uint GL_OES_fbo_render_mipmap GL_OES_get_program_binary GL_OES_mapbuffer GL_OES_packed_depth_stencil GL_OES_rgb8_rgba8 GL_OES_standard_derivatives GL_OES_texture_3D GL_OES_texture_float GL_OES_texture_float_linear GL_OES_texture_half_float GL_OES_texture_half_float_linear GL_OES_texture_npot GL_OES_vertex_array_object GL_OES_vertex_half_float GL_SGIS_generate_mipmap GL_SGIS_texture_lod GL_SGIX_depth_texture GL_SGIX_shadow GL_SUN_slice_accum GL_WIN_swap_hint WGL_EXT_swap_control
tmwinogl: wgl extensions=WGL_ARB_buffer_region WGL_ARB_create_context WGL_ARB_create_context_profile WGL_ARB_create_context_robustness WGL_ARB_extensions_string WGL_ARB_make_current_read WGL_ARB_multisample WGL_ARB_pbuffer WGL_ARB_pixel_format WGL_ARB_pixel_format_float WGL_ARB_render_texture WGL_ATI_pixel_format_float WGL_EXT_create_context_es2_profile WGL_EXT_extensions_string WGL_EXT_framebuffer_sRGB WGL_EXT_pixel_format_packed_float WGL_EXT_swap_control WGL_NVX_DX_interop WGL_NV_DX_interop WGL_NV_DX_interop2 WGL_NV_float_buffer WGL_NV_multisample_coverage WGL_NV_render_depth_texture WGL_NV_render_texture_rectangle
tmwinogl: extensions used=(anisotropic filter of 16.00) (texture array) (gpu shader4) (texture rgtc compression) (directstateaccess) (uniform_buffer_object) (drawelementsinstanced) (drawelementsbasevertex) (texturebufferobject) (occlusionquery) (tessellation) (shaderbufferload) (vertexbufferunifiedmemory) (swapcontrol)
tmwinogl: gl: using depthmap texture array
tmwinogl:
tmopenal: init= (default=Generic Software) (0:Generic Software) (version=1.1) (1.1) ok
sim:
sim: FUNC RenderOpen BEGIN
sim:
tmxgltext: loading font (0) 'texture/fontbig.tff'=(512x256) (h=26) (nc=256) ok
tmxgltext: loading font (1) 'texture/fontbig.tff'=(512x256) (h=26) (nc=256) ok
tmxgltext: loading font (2) 'texture/console.tff'=(256x128) (h=15) (nc=256) ok
tmxgltext: loading font (3) 'texture/font.tff'=(2048x2048) (h=17) (nc=65535) ok
tminput: searching for input devices...(3)
win32usbinput: searching usb interface (0,0)=(joyinterface) cb913b0c
tmwinjoystick: searching joysticks=(skipping IKARUS input)none
tminput: 1 devices found= (USB GameCommander #1) (cb913b0c)
tmmusic: (11 mp3 files found) (playlist = 0 songs)off
sim: loading scenery 'scenery//us-bennetfield'...
tmscene: (10x10) (23x8) (r=5000.00) (sp=-0.86 1.87 1.83) (vp=0.00 0.00 1.80) (ambient=0.05 0.08 0.12) (diffuse=1.09 1.09 1.09) (sphereambient=0.22 0.00 0.00)
tm_scenery_extras: found runway Asphalt
tm_scenery_extras: found corners: -108.57 29.46 -0.31, -108.57 -1.38 -0.14, -23.93 -1.38 -0.07, -23.99 -19.81 -0.08, -18.11 -19.75 -0.02, -18.10 -5.73 -0.05, 17.25 -5.66 0.00, 17.28 -18.49 -0.01, 22.95 -18.38 0.01, 22.95 -1.20 0.01, 107.96 -1.16 0.20, 108.61 29.46 0.06, 75.52 29.46 -0.00, 75.52 47.31 -0.04, 52.60 46.97 -0.06, 52.39 29.46 -0.05, -52.58 29.47 -0.23, -52.56 46.40 -0.11, -76.65 46.40 -0.13, -76.65 29.47 -0.27,
tm_scenery_extras: found pivots: -85.00 14.00 -0.07, 85.00 14.00 0.09,
tm_scenery_extras: found directions: 1.00 0.00 0.00, -1.00 0.00 0.00,
tm_scenery_extras: Loading Pylon Geometry 'objects/pylon_race/pylons_f5d.tgb'
tm_scenery_extras: Loading Limbo Geometry 'objects/limbo_contest/limbo_contest.tgb'
tm_scenery_extras: Loading Limbo Geometry 'objects/limbo_contest/limbo_contest_big.tgb'
tmxgltext: 134 textures using 102 MB
tmcollision: init = (tris=37135, 7724080 bytes) (-3512.46 -3512.46 -135.87 - 3818.30 3548.29 313.90) (time=0.13s)
tmcollision: (710 input objects) (6 base objects) (11 instance objects) (0 dynamic objects) (time=0.00s)
tmfile: loading tmfile 'config/scenery-us-bennetfield.tmc' = (857 bytes) done
tmcollision: creating static collisionobjects quadtree = (objects=11) (-3512.47 -3512.47 -135.88) - (3818.31 3548.30 313.91)
tm_scenery_extras: Positioned Limbo with h = 2.08, w = 2.44
tm_scenery_extras: Positioned Limbo with h = 5.20, w = 6.10
tm_scenery_extras: Loading Spot Landing Geometry 'scenery/us-bennetfield/spot_landing01.tgb'
tm_scenery_extras: Loading Spot Landing Geometry 'scenery/us-bennetfield/spot_landing02.tgb'
tm_scenery_extras: Loading Spot Landing Geometry 'scenery/us-bennetfield/spot_landing_heli.tgb'
tmscene: scene bounding box = (2541.23 3134.86 -135.87) (3818.30 3494.73 243.16)
tmscene: max objects per cell = 409
tmcollision: updating static collisionobjects quadtree = (objects=31) (-3512.47 -3512.47 -135.88) - (3818.31 3548.30 313.91)
tmscene: shadowmap = 2048x2048 sp=4 (10.00 43.00 185.50 800.00 0.00 0.00 0.00)
sim: done loading scenery (t=1.89s objects=708)
sim:
sim: windfieldinfo 0: resolution=2.00 min=(-1000.00 -1000.00 0.00) max=(1000.00 1000.00 100.00)
tmwindfield: Setup Windfield with origin = (-1000.0, -1000.0, 0.0), size_xy = (2000.0m, 2000.0m), Grid relation (x:y): 1:1, MipMapLevels: 10, Resolution: (2.0m, 2.0m)
tmwindfield: Windfield Map Load from file 'scenery/us-bennetfield/windfield0.twd' successful
tmscene: statistics = (objects=888) (transparent=142) (graphics=98) (graphicsbb=0) (dynamic=0) (decals=0) (water=0) (tris=10732) (shadow faces=0) (btrees=0) (trees=0)
tmfile: loading tmfile 'config/player0.mcf' = (2316 bytes) done
sim: loading model 'yak55sp'...
sim: path='aircraft/yak55sp' geometry='yak55sp' physics='yak55sp' paintscheme='' ...
tmmodelmanager: assigning controller to receiver
tmmodelmanager: model input channel Throttle Aileron Elevator Rudder
sim: done loading model (t=0.28s, n=66, id=59)
sim:
tmfile: loading tmfile 'config/player1.mcf' = (2307 bytes) done
tmfile: loading tmfile 'menu/settings.mcf' = (97683 bytes) done
tmmodelmanager: (0:airfoil) (1:airfoil) (2:airfoil) (3:airfoil) (4:airfoil) (5:airfoil)
tmmodelmanager: (6:airfoil) (7:airfoil) (8:airfoil) (9:airfoil) (10:airfoil) (11:airfoil) (12:airfoil) loading tmfile 'config/ugc0-cb913b0c.tmc' = (73421 bytes) done
trackir: initializing trackir...
trackir: DLL Location key not presentTrackIR dll not found (dll location: 'Error')
tmxgltext: 465 textures using 162 MB
sim:
sim: FUNC RenderOpen END = 4.586843 sec
sim:
tm: calibrating radio deviations= 0 3 6 9 -16 25 -36 88
license: license: tml file 'af5-c010.tml' = C010 0000 0507 0101 'aerofly5' 'C010-CB913B0C.lic' (activated=1)
tmsyswin: COMPUTETHREAD CLOSE OK
sim: FUNC Shutdown
trackir: shutting down trackir...
tmopenal: shutdown=ok
tmwinogl:
sim:
sim:
sim:
sim:
sim:
sim:
sim: FUNC Shutdown
