Ikarus Aerofly flight simulators Get the answers to your technical questions about Ikarus' Aerofly flight simulators here in their official support forum
Aerofly 5.7.1.1
Reply
Old 12-02-2011, 07:30 PM
SpeedBird
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Aerofly 5.7.1.1
Raj,
I am running bootcamp with my macbook pro, 2010, geforce 9600m, with 8gig ram.
I installed 5.5 and upgraded to 5.7
My fps were initially 130-150
After the upgrade to 5.7, it went down to 20 fps.
I unloaded some start up items, and Iwas able to get it in the 100 range.
After a crash, the fps go down to 70.
After another crash, the fps go down to 40.
I know, I should not crash.
But it seems the program crashes when after I crash.
Suggestions please.
Thanks in advance.
SpeedBird is offline
Old 12-02-2011, 07:39 PM
rajul
My Feedback: (58)
rajul's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Aerofly 5.7.1.1
Please post your tmlog file here. You can find the tmlog file in your main AF5 directory, open it with a text editor, then copy and paste the full content.
rajul is offline
Old 12-02-2011, 07:49 PM
SpeedBird
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
tmmodule: (7 modules) (tmatmosphere,1) (tmsystimer,1) (tmrandom,2) (tmfile,4) (tmwinjoystick,10) (tmwinogl,10) (tmopenal,20)
tmmodule: init modules=(tmsystimer=ok) (tmrandom=(seed=566612903) ok) done
tmsyswin: Program version 5.7.1.1
tmsyswin: Library Version 5.6, Copyright (C) 1999-2011, IPACS
tmsyswin: http://www.ipacs.de
tmsyswin: memory=(physical=8167MB, avail=0MB) (virtual=7225MB, avail=0MB) (16333 in use)
tmsyswin: operating system=Microsoft Windows 7 Version 6.1 Service Pack 1 (Build 7601) Service Pack: Service Pack 1 (Build 7601)
tmfile: loading tmfile 'config/main.mcf' = (4762 bytes) done
tmsyswin: fullscreen modes=(1152x864x32x60) (1280x768x32x60) (1280x800x32x60) (1360x768x32x60) (1366x768x32x60) (1440x900x16x60)
tmsyswin: init window=(mdf=60Hz) (window=0x0x1376x768) (client=1376x768) (screen=1440x900) (32bpp) (60Hz) (windowed mode)
tmwinogl: initializing opengl= (samplebuffers=0) (colorbits=32) (stencilbits=0) (depthbits=0)
tmwinogl: (compiling test shader= ok) (version=3.3) (compatibility profile) (vendor=NVIDIA Corporation) (renderer=GeForce 9600M GT/PCI/SSE2) (version=3.3.0)
tmwinogl: opengl caps=(viewport=8192x8192) (texsize=8192) (texsize3d=0) (stencil=96) (texunits=32) (ps-texunits=0) (shading_language=3.30 NVIDIA via Cg compiler) (shader_max_vertex=4096) (shader_max_fragment=2048)
tmwinogl: gl extensions=GL_ARB_base_instance GL_ARB_blend_func_extended GL_ARB_color_buffer_float GL_ARB_compatibility GL_ARB_compressed_texture_pixel_storage GL_ARB_conservative_depth GL_ARB_copy_buffer GL_ARB_depth_buffer_float GL_ARB_depth_clamp GL_ARB_depth_texture GL_ARB_draw_buffers GL_ARB_draw_elements_base_vertex GL_ARB_draw_instanced GL_ARB_ES2_compatibility GL_ARB_explicit_attrib_location GL_ARB_fragment_coord_conventions GL_ARB_fragment_program GL_ARB_fragment_program_shadow GL_ARB_fragment_shader GL_ARB_framebuffer_object GL_ARB_framebuffer_sRGB GL_ARB_geometry_shader4 GL_ARB_get_program_binary GL_ARB_half_float_pixel GL_ARB_half_float_vertex GL_ARB_imaging GL_ARB_instanced_arrays GL_ARB_internalformat_query GL_ARB_map_buffer_alignment GL_ARB_map_buffer_range GL_ARB_multisample GL_ARB_multitexture GL_ARB_occlusion_query GL_ARB_occlusion_query2 GL_ARB_pixel_buffer_object GL_ARB_point_parameters GL_ARB_point_sprite GL_ARB_provoking_vertex GL_ARB_robustness GL_ARB_sampler_objects GL_ARB_seamless_cube_map GL_ARB_separate_shader_objects GL_ARB_shader_bit_encoding GL_ARB_shader_objects GL_ARB_shading_language_100 GL_ARB_shading_language_420pack GL_ARB_shading_language_include GL_ARB_shading_language_packing GL_ARB_shadow GL_ARB_sync GL_ARB_texture_border_clamp GL_ARB_texture_buffer_object GL_ARB_texture_compression GL_ARB_texture_compression_rgtc GL_ARB_texture_cube_map GL_ARB_texture_env_add GL_ARB_texture_env_combine GL_ARB_texture_env_crossbar GL_ARB_texture_env_dot3 GL_ARB_texture_float GL_ARB_texture_mirrored_repeat GL_ARB_texture_multisample GL_ARB_texture_non_power_of_two GL_ARB_texture_rectangle GL_ARB_texture_rg GL_ARB_texture_rgb10_a2ui GL_ARB_texture_storage GL_ARB_texture_swizzle GL_ARB_timer_query GL_ARB_transpose_matrix GL_ARB_uniform_buffer_object GL_ARB_vertex_array_bgra GL_ARB_vertex_array_object GL_ARB_vertex_buffer_object GL_ARB_vertex_program GL_ARB_vertex_shader GL_ARB_vertex_type_2_10_10_10_rev GL_ARB_viewport_array GL_ARB_window_pos GL_ATI_draw_buffers GL_ATI_texture_float GL_ATI_texture_mirror_once GL_S3_s3tc GL_EXT_texture_env_add GL_EXT_abgr GL_EXT_bgra GL_EXT_bindable_uniform GL_EXT_blend_color GL_EXT_blend_equation_separate GL_EXT_blend_func_separate GL_EXT_blend_minmax GL_EXT_blend_subtract GL_EXT_compiled_vertex_array GL_EXT_Cg_shader GL_EXT_depth_bounds_test GL_EXT_direct_state_access GL_EXT_draw_buffers2 GL_EXT_draw_instanced GL_EXT_draw_range_elements GL_EXT_fog_coord GL_EXT_framebuffer_blit GL_EXT_framebuffer_multisample GL_EXTX_framebuffer_mixed_formats GL_EXT_framebuffer_object GL_EXT_framebuffer_sRGB GL_EXT_geometry_shader4 GL_EXT_gpu_program_parameters GL_EXT_gpu_shader4 GL_EXT_multi_draw_arrays GL_EXT_packed_depth_stencil GL_EXT_packed_float GL_EXT_packed_pixels GL_EXT_pixel_buffer_object GL_EXT_point_parameters GL_EXT_provoking_vertex GL_EXT_rescale_normal GL_EXT_secondary_color GL_EXT_separate_shader_objects GL_EXT_separate_specular_color GL_EXT_shadow_funcs GL_EXT_stencil_two_side GL_EXT_stencil_wrap GL_EXT_texture3D GL_EXT_texture_array GL_EXT_texture_buffer_object GL_EXT_texture_compression_dxt1 GL_EXT_texture_compression_latc GL_EXT_texture_compression_rgtc GL_EXT_texture_compression_s3tc GL_EXT_texture_cube_map GL_EXT_texture_edge_clamp GL_EXT_texture_env_combine GL_EXT_texture_env_dot3 GL_EXT_texture_filter_anisotropic GL_EXT_texture_format_BGRA8888 GL_EXT_texture_integer GL_EXT_texture_lod GL_EXT_texture_lod_bias GL_EXT_texture_mirror_clamp GL_EXT_texture_object GL_EXT_texture_shared_exponent GL_EXT_texture_sRGB GL_EXT_texture_sRGB_decode GL_EXT_texture_storage GL_EXT_texture_swizzle GL_EXT_texture_type_2_10_10_10_REV GL_EXT_timer_query GL_EXT_vertex_array GL_EXT_vertex_array_bgra GL_EXT_import_sync_object GL_IBM_rasterpos_clip GL_IBM_texture_mirrored_repeat GL_KTX_buffer_region GL_NV_alpha_test GL_NV_blend_minmax GL_NV_blend_square GL_NV_complex_primitives GL_NV_conditional_render GL_NV_copy_depth_to_color GL_NV_copy_image GL_NV_depth_buffer_float GL_NV_depth_clamp GL_NV_explicit_multisample GL_NV_fbo_color_attachments GL_NV_fence GL_NV_float_buffer GL_NV_fog_distance GL_NV_fragdepth GL_NV_fragment_program GL_NV_fragment_program_option GL_NV_fragment_program2 GL_NV_framebuffer_multisample_coverage GL_NV_geometry_shader4 GL_NV_gpu_program4 GL_NV_half_float GL_NV_light_max_exponent GL_NV_multisample_coverage GL_NV_multisample_filter_hint GL_NV_occlusion_query GL_NV_packed_depth_stencil GL_NV_parameter_buffer_object GL_NV_parameter_buffer_object2 GL_NV_path_rendering GL_NV_pixel_data_range GL_NV_point_sprite GL_NV_primitive_restart GL_NV_register_combiners GL_NV_register_combiners2 GL_NV_shader_buffer_load GL_NV_texgen_reflection GL_NV_texture_barrier GL_NV_texture_compression_vtc GL_NV_texture_env_combine4 GL_NV_texture_expand_normal GL_NV_texture_lod_clamp GL_NV_texture_multisample GL_NV_texture_rectangle GL_NV_texture_shader GL_NV_texture_shader2 GL_NV_texture_shader3 GL_NV_transform_feedback GL_NV_vertex_array_range GL_NV_vertex_array_range2 GL_NV_vertex_buffer_unified_memory GL_NV_vertex_program GL_NV_vertex_program1_1 GL_NV_vertex_program2 GL_NV_vertex_program2_option GL_NV_vertex_program3 GL_NVX_conditional_render GL_NVX_gpu_memory_info GL_OES_depth24 GL_OES_depth32 GL_OES_depth_texture GL_OES_element_index_uint GL_OES_fbo_render_mipmap GL_OES_get_program_binary GL_OES_mapbuffer GL_OES_packed_depth_stencil GL_OES_rgb8_rgba8 GL_OES_standard_derivatives GL_OES_texture_3D GL_OES_texture_float GL_OES_texture_float_linear GL_OES_texture_half_float GL_OES_texture_half_float_linear GL_OES_texture_npot GL_OES_vertex_array_object GL_OES_vertex_half_float GL_SGIS_generate_mipmap GL_SGIS_texture_lod GL_SGIX_depth_texture GL_SGIX_shadow GL_SUN_slice_accum GL_WIN_swap_hint WGL_EXT_swap_control
tmwinogl: wgl extensions=WGL_ARB_buffer_region WGL_ARB_create_context WGL_ARB_create_context_profile WGL_ARB_create_context_robustness WGL_ARB_extensions_string WGL_ARB_make_current_read WGL_ARB_multisample WGL_ARB_pbuffer WGL_ARB_pixel_format WGL_ARB_pixel_format_float WGL_ARB_render_texture WGL_ATI_pixel_format_float WGL_EXT_create_context_es2_profile WGL_EXT_extensions_string WGL_EXT_framebuffer_sRGB WGL_EXT_pixel_format_packed_float WGL_EXT_swap_control WGL_NVX_DX_interop WGL_NV_DX_interop WGL_NV_DX_interop2 WGL_NV_float_buffer WGL_NV_multisample_coverage WGL_NV_render_depth_texture WGL_NV_render_texture_rectangle
tmwinogl: extensions used=(anisotropic filter of 16.00) (texture array) (gpu shader4) (texture rgtc compression) (directstateaccess) (uniform_buffer_object) (drawelementsinstanced) (drawelementsbasevertex) (texturebufferobject) (occlusionquery) (tessellation) (shaderbufferload) (vertexbufferunifiedmemory) (swapcontrol)
tmwinogl: gl: using depthmap texture array
tmwinogl:
tmopenal: init= (default=Generic Software) (0:Generic Software) (version=1.1) (1.1) ok
sim:
sim: FUNC RenderOpen BEGIN
sim:
tmxgltext: loading font (0) 'texture/fontbig.tff'=(512x256) (h=26) (nc=256) ok
tmxgltext: loading font (1) 'texture/fontbig.tff'=(512x256) (h=26) (nc=256) ok
tmxgltext: loading font (2) 'texture/console.tff'=(256x128) (h=15) (nc=256) ok
tmxgltext: loading font (3) 'texture/font.tff'=(2048x2048) (h=17) (nc=65535) ok
tminput: searching for input devices...(3)
win32usbinput: searching usb interface (0,0)=(joyinterface) cb913b0c
tmwinjoystick: searching joysticks=(skipping IKARUS input)none
tminput: 1 devices found= (USB GameCommander #1) (cb913b0c)
tmmusic: (11 mp3 files found) (playlist = 0 songs)off
sim: loading scenery 'scenery//us-bennetfield'...
tmscene: (10x10) (23x8) (r=5000.00) (sp=-0.86 1.87 1.83) (vp=0.00 0.00 1.80) (ambient=0.05 0.08 0.12) (diffuse=1.09 1.09 1.09) (sphereambient=0.22 0.00 0.00)
tm_scenery_extras: found runway Asphalt
tm_scenery_extras: found corners: -108.57 29.46 -0.31, -108.57 -1.38 -0.14, -23.93 -1.38 -0.07, -23.99 -19.81 -0.08, -18.11 -19.75 -0.02, -18.10 -5.73 -0.05, 17.25 -5.66 0.00, 17.28 -18.49 -0.01, 22.95 -18.38 0.01, 22.95 -1.20 0.01, 107.96 -1.16 0.20, 108.61 29.46 0.06, 75.52 29.46 -0.00, 75.52 47.31 -0.04, 52.60 46.97 -0.06, 52.39 29.46 -0.05, -52.58 29.47 -0.23, -52.56 46.40 -0.11, -76.65 46.40 -0.13, -76.65 29.47 -0.27,
tm_scenery_extras: found pivots: -85.00 14.00 -0.07, 85.00 14.00 0.09,
tm_scenery_extras: found directions: 1.00 0.00 0.00, -1.00 0.00 0.00,
tm_scenery_extras: Loading Pylon Geometry 'objects/pylon_race/pylons_f5d.tgb'
tm_scenery_extras: Loading Limbo Geometry 'objects/limbo_contest/limbo_contest.tgb'
tm_scenery_extras: Loading Limbo Geometry 'objects/limbo_contest/limbo_contest_big.tgb'
tmxgltext: 134 textures using 102 MB
tmcollision: init = (tris=37135, 7724080 bytes) (-3512.46 -3512.46 -135.87 - 3818.30 3548.29 313.90) (time=0.13s)
tmcollision: (710 input objects) (6 base objects) (11 instance objects) (0 dynamic objects) (time=0.00s)
tmfile: loading tmfile 'config/scenery-us-bennetfield.tmc' = (857 bytes) done
tmcollision: creating static collisionobjects quadtree = (objects=11) (-3512.47 -3512.47 -135.88) - (3818.31 3548.30 313.91)
tm_scenery_extras: Positioned Limbo with h = 2.08, w = 2.44
tm_scenery_extras: Positioned Limbo with h = 5.20, w = 6.10
tm_scenery_extras: Loading Spot Landing Geometry 'scenery/us-bennetfield/spot_landing01.tgb'
tm_scenery_extras: Loading Spot Landing Geometry 'scenery/us-bennetfield/spot_landing02.tgb'
tm_scenery_extras: Loading Spot Landing Geometry 'scenery/us-bennetfield/spot_landing_heli.tgb'
tmscene: scene bounding box = (2541.23 3134.86 -135.87) (3818.30 3494.73 243.16)
tmscene: max objects per cell = 409
tmcollision: updating static collisionobjects quadtree = (objects=31) (-3512.47 -3512.47 -135.88) - (3818.31 3548.30 313.91)
tmscene: shadowmap = 2048x2048 sp=4 (10.00 43.00 185.50 800.00 0.00 0.00 0.00)
sim: done loading scenery (t=1.89s objects=708)
sim:
sim: windfieldinfo 0: resolution=2.00 min=(-1000.00 -1000.00 0.00) max=(1000.00 1000.00 100.00)
tmwindfield: Setup Windfield with origin = (-1000.0, -1000.0, 0.0), size_xy = (2000.0m, 2000.0m), Grid relation (x:y): 1:1, MipMapLevels: 10, Resolution: (2.0m, 2.0m)
tmwindfield: Windfield Map Load from file 'scenery/us-bennetfield/windfield0.twd' successful
tmscene: statistics = (objects=888) (transparent=142) (graphics=98) (graphicsbb=0) (dynamic=0) (decals=0) (water=0) (tris=10732) (shadow faces=0) (btrees=0) (trees=0)
tmfile: loading tmfile 'config/player0.mcf' = (2316 bytes) done
sim: loading model 'yak55sp'...
sim: path='aircraft/yak55sp' geometry='yak55sp' physics='yak55sp' paintscheme='' ...
tmmodelmanager: assigning controller to receiver
tmmodelmanager: model input channel Throttle Aileron Elevator Rudder
sim: done loading model (t=0.28s, n=66, id=59)
sim:
tmfile: loading tmfile 'config/player1.mcf' = (2307 bytes) done
tmfile: loading tmfile 'menu/settings.mcf' = (97683 bytes) done
tmmodelmanager: (0:airfoil) (1:airfoil) (2:airfoil) (3:airfoil) (4:airfoil) (5:airfoil)
tmmodelmanager: (6:airfoil) (7:airfoil) (8:airfoil) (9:airfoil) (10:airfoil) (11:airfoil) (12:airfoil) loading tmfile 'config/ugc0-cb913b0c.tmc' = (73421 bytes) done
trackir: initializing trackir...
trackir: DLL Location key not presentTrackIR dll not found (dll location: 'Error')
tmxgltext: 465 textures using 162 MB
sim:
sim: FUNC RenderOpen END = 4.586843 sec
sim:
tm: calibrating radio deviations= 0 3 6 9 -16 25 -36 88
license: license: tml file 'af5-c010.tml' = C010 0000 0507 0101 'aerofly5' 'C010-CB913B0C.lic' (activated=1)
tmsyswin: COMPUTETHREAD CLOSE OK
sim: FUNC Shutdown
trackir: shutting down trackir...
tmopenal: shutdown=ok
Old 12-03-2011, 05:53 AM
SpeedBird
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I hope that helps. Ty
Old 12-04-2011, 08:18 AM
rajul
My Feedback: (58)
rajul's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Please try to upgrade your 3d card driver and aerofly5 to v5.7.1.5. You should also disable any program running in the background, including scanning for any viruses and adwares.
rajul is offline
Contact Us Archive Advertising Cookie Policy
