Ikarus Aerofly flight simulators Get the answers to your technical questions about Ikarus' Aerofly flight simulators here in their official support forum
FYI Installing 5.7.7.1 on Mac OSX10.6.8
Reply
Old 03-16-2013, 01:49 PM
ic-racer
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default FYI Installing 5.7.7.1 on Mac OSX10.6.8
To install the 5.7.7.1 upgrade I had to re-name my prior upgraded program from "AeroFly 5 Update Version 5.5.0.7.app" to "aerofly5.app" for the installer to work. Otherwise I got an error that it can't find the "aerofly5" application, even though I had followed the directions indicated.
ic-racer is offline
Old 03-18-2013, 03:10 AM
rajul
rajul's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: FYI Installing 5.7.7.1 on Mac OSX10.6.8
You must not rename the update file! Here are the instructions from www.aerofly.com:
Once the download is complete mount af5-mac-update-v5070701.dmg file by double clicking on it. Then copy the application “af5-mac-update-v5070701” into your aerofly5 folder. Then double click on “af5-mac-update-v5070701” to start the update process.
Looks like you're also downloading the wrong update version 5.5.0.7 when what you should download is version 5.7.7.1
rajul is offline
Old 03-18-2013, 12:21 PM
ic-racer
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Maybe it was not clear but I had to rename my PRIOR UPGRADED program (that was named by the last version updater, not by me) from "AeroFly 5 Update Version 5.5.0.7.app" to "aerofly5.app" for the 5.7.7.1 updater to work. After doing that it updated just fine to 5.7.7.1. Without doing that there was an error message saying "aerofly5.app" could not be found, even though it was in the same folder as the updater (per the instructions).
ic-racer is offline
Old 03-19-2013, 03:08 AM
rajul
rajul's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The app "AeroFly 5 Update Version 5.5.0.7.app" is just the installer of version 5.5.0.7 and can be removed after installation. This installer must be in the aerofly5 folder. In the aerofly5 folder is the actual app called either "Aerofly 5" or "aerofly5".
rajul is offline
Old 03-21-2013, 04:52 PM
ic-racer
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Rajul , thanks for pointing out the expected behavior of the files. Looks like something odd must have happened to me with the last updater, causing my "Aerofly 5.app" to be renamed to "AeroFly 5 Update Version 5.5.0.7.app" because after that update I no longer had "Aerofly 5.app" in my folder and when I clicked on "AeroFly 5 Update Version 5.5.0.7.app" it no longer ran the updater, but started the simulator. I wonder if that happened to anyone else after the 5.5.07 update? (iMac 27" OSX 10.6.8, 2.93GHz Intel Core i7)
ic-racer is offline
Reply
Display Modes
