Recognition of Futaba 18MZ
Hi,
I used to used Aerofly Pro Deluxe a few years back but now my 8yr old has been bitten by the bug I thought it only fair to download the latest version for him to practice on.
So, last night I downloaded Aerofly 7 from the AppStore on our Mac.
I now own the Futaba 18MZ so tried to use the lead I used for my 14MZ but could not get it to detect the transmitter.
I'm not sure if the old lead from aerofly pro works with Aerofly 7 or if I can use the 18MZ?? I seem to remember I had to remove the RF module from the 14MZ and put it in PPM mode. Are there equivalent steps to take on the 18MZ??
Attached is a pic of the lead I am using.
Any help gratefully received as I have a very excited/disappointed 8yr old
Moderator
My Feedback: (58)
I am using the 14mz with RC7. You need to plug in the FM module and set the 14mz to 8-channel PPM modulation. The other two modulations available are the 12-channel PPM (N1.3) and 12-channel PPM (N1.5). The N represents the PPM pulse width. I think the 8-channel PPM is using N1.0 by default, which is the standard PPM modulation that is compatible with the usb interface. I am not familiar with the 18mz, but please check the PPM modulation as well.
Your cables will work with RC7.
Hi Mike
Thanks but I am using an 18MZ. There is no ability to plug in/remove a module or set the TX to PPM mode.
My mention of the 14MZ was what I used to use before I sold it for the 18MZ....
Rgds,
Mark
Rgds,
Mark
Hi Mike
Sorry, bit lost. If the trainer port is in PPM, why should I disable the trainer mode in the radio? Don't we need a PPM output??
Re the lead - it was a while ago but has only been sat in the draw for a year.
Rgds,
Mark
Rgds,
Mark
