Exhaust7Smoke options in AFP deluxe
Just recieved my AFP DL program and it looks great so far. But when I´m trying to activate the smoke or exhaust options, nothing happens.. I tick the boxes for this but still, no smoke or exhaust is visible. Any other setting that needs to be done..?
Regards,
Richard
Regards,
Richard
My Feedback: (28)
IA
RE: Exhaust7Smoke options in AFP deluxe
Ok once i would get to the notepad where would i be able to how would i assign the switch on my aeroflypro i can get smoke but on my channel 5 switch on my hitec ecipse radio normally the toggle switch for channel 5 shuts on and off the smoke. Now it doesnt on the simulator. It has been calabrated on channel 5 . When i calibrate the channel 5 and move switch it is showing that it is working proper . It goes all the way over on the red bars on the calibrate section then when i toggle the swtch it moves the other way.
My Feedback: (28)
IA
Do you mean under the menu and graphics on the top of the screen where it says smoke and exhaust , yes i do . If you mean where you go and configure your radio setup the only thing i see is the channel 5 retract option. By the way thanks for all your support to us dumb computer operators. I finally figured how to increase the smoke density, works awesome now.
