Futaba Micro Plug
My Feedback: (59)
Futaba Micro Plug
Dion, I just opened my AFPD and was shocked to find out that the adapter cord was for the old style radios with the big round plugs and not the new micro square plug after me specifically telling you that my radio was a 6EXA and asking you well before placing my order online if the sim worked with my TX. Your reply was a definate YES and that all i needed to do was install the software and plug in my TX as everything needed was included .. To bad i didn't read the web site where it states :
Supported transmitters for AeroFly Pro
and AeroFly Pro Deluxe:
- Futaba (New generation Futaba 4YF, 6EX, 7C, 9C, 14MX require the new Futaba Micro Adapter)
- JR (New generation JR 2610, 6102, 9303, 10X require the JR Micro Adapter)
- Hitec
- Multiplex
- Airtronics
- Lexors
- Graupner
- Sanwa
- Robbe
So for future customers PLEASE BE ADVISED THAT IF YOU GO WITH AFPD non Commander Version, YOU WILL NEED TO PURCHASE THE FUTABA MICRO PLUG WHEN YOU ORDER THE PROGRAM.
THANKS
- Hitec
- Multiplex
- Airtronics
- Lexors
- Graupner
- Sanwa
- Robbe
THANKS
My Feedback: (21)
NY
RE: Futaba Micro Plug
Sorry about that.
I usually ask everyone if their plug is square or round. But I didn't know that the 6EXA and the 6EX were the same or that there were 2 models.
In the meantime do you have any other radios to use?
My Feedback: (59)
No all my old radios are just that OLD more then 10 years and the batteries more then likely won't hold a charge. Until the plug gets here i'm just messing around with the sim using a dual stick gamepad.
If your old transmitter batteries wont hold a charge, just use a cheap 10 or 12 volt transformer from Maplin, Radio Spares or Radio Shack etc to power your tranmitter. I am using one to power my Futaba or Hitec set depending which one I am using.
The battery packs supply voltage through a standard servo plug into the transmitters i use, so I just replaced the connector on the transformer with an old servo lead, hey presto mains powered transmitter and no need for batteries. Possibly a good idea for using any transmitter that uses a battery pack with a plug save having to recharge all the time.
