Can't get "Vettre" scenery to work
Hi all...
I downloaded the "vettre" scenery, unzipped the file into its folder in the "scenery" folder and changed the jpg files to bmp files. I also checked the "texture" file and it was set to 2048. I'm only getting a black screen and can barely make out the aircraft...I'm at a loss?????
Thanks in advance for help...
John
John
My Feedback: (29)
IA
RE: Can't get "Vettre" scenery to work
I have the same problem as John, well almost, I just get a black screen and computer lock-up when I tried to open it. I finally deleted all the "vettre" files so I could use my AFP. What patch are you talking about? I downloaded the latest patch for AFP when I bought and installed it. Is there a patch for "vettre"? Also what is this thing about "texture"? I haven't made any changes there.
Ron
Ron
MA
First off... do you have AFPD or AFP?
Right now don't worry about the texture...the texture has more to do about performance then the blackened screen
MA
also Ron.....if you have the Vettre folder in the scenery folder with all the jpg.'s converted to bmp.'s make sure you also have these 3 files in the scenery folder..
* vettre.geo
after i downloaded the file and opened it i saw those 3 files and the vettre folder...so make sure those 3 files go in the scenery folder and not the Vettre folder
* vettre.geo
My Feedback: (29)
IA
OK, did all that and this time it WORKS!!!! I thought I had done all that before, but I guess I nad screwed something up.[>:]
Thanks for the help. I'm going flying.[8D]
Ron
Ron
AK
Well someone give me a hand,,ive tried everything ,,keep getting black screen and black planes,,,converted Jpegs to bmp,,,still doesnt work,,made sure i had the corrects files in the scenery folder ,,still black screen,ive tried it 4 or 5 times same results each time,,
Bob
Bob
MA
....i don't uderstand why you are having problems but you must be doing something wrong....uninstall everything about Vettre and try again with these instructions...
Installation:
1. Extract this ZIP-file to the 'scenery'-folder of your AeroFly Professional installation.
There will be a new folder 'vettre' created which contains several pictures and files. In addition after extraction these three files should be located in the 'scenery'-folder:
* vettre.geo
If not, simply move them to there.
2. Then go into the 'vettre'-folder and convert the JPEGs into BMPs.
NOTE: do not rename the files. That does not work. You have to load them into a graphics viewer such as 'IrfanView' or 'ACDSee' and store them again in the BMP format.
Installation:
* vettre.geo
AK
tukkus
Thats excactly what ive been doing,,,but for converting im useing photoshop instead,,maybe thats the problem,,,ive been doing it excactly like you just listed,,,but im useing photoshop to convert the jpegs to bmp,,,i wonder is something there is going wrong.
Bob
tukkus
I went and downloaded IrfanView and did excactly like you said,,,got the excat same results,,,AFPD works perfect of m system,,ive downloaded dozens of planes,,but when i download the scerney and change jpegs to bmp,this is what i get
Bob
tukkus
NdFrSpeed, tukkus
I have done this as you have and other people have, followed yours and their instructions many times, and i cant get it to work. all i can say is it works on some computor systems and not others why i dont know.
P.S. I get the same prob as NdFrSpeed and i convert jpg to bmp via irfanview.
"I Need some search lights" (vettre scenery) IN AFPD. Also ive tried GEO file to alter lighting ect,you can read it but page is locked cant alter.
Regards Dave.
Regards Dave.
My Feedback: (29)
IA
This is a screen shot of my scenery file. My "Vettre" works now. I had a lot of trouble before yesterday. I could not get it either. I tried one more time and now it works. Maybe this helps.
Ron
Ron
OR
(I've got Deluxe) editing the .geo and .obj files turns the lights on. Should of set a link to the post but.... do a search for "obj" "file" and it explains how.
Joel
Joel
MA
ok, it's an easy fix......
go into the AFPD scenery folder and open the file named Vettre.GEO...then simply add these four lines along with the others...
LIGHT_POSITION 0 0.20 -0.40 1.00 0
LIGHT_AMBIENT 0 0.55 0.55 0.55
LIGHT_DIFFUSE 0 1.00 1.00 1.00
LIGHT_SPECULAR 0 1.00 1.00 1.00
HI TUKKAS
When i go into the GEO file open page up in m soft word the page you can read but i cant alter any lines as the page is locked
how do i unlock the page to do the alterations.
Regards Dave.
Regards Dave.
HI TUKKAS
Got ms word working now and i added those 4 lines in to the GEO FILE and saved but still comes up dark screen.
