Won't Run
Won't Run
I have All In Wonder 128 Pro AMD ATHLON 1.6MHZ win98 1024/768 16 BIT K7S5A MOTHERBOARD
Aerofly Professional ran on this, But Aerofly Professional Deluxe
Gets as far as loading Christian Eagle
Then all I get is Illegal Operation Message Box
I have reinstalled ATI Driver and Aerofly Professional Deluxe about 10 times and am now well ****** off with this program !!
BTW it only runs through to start screen without an open gl driver installed
BTW Easy Fly still runs
What next ?????
Martin
What next ?????
Martin
RE: Won't Run
hi,
all in wonder graphics cards aren't recomended for afpd, try updating your graphics drivers and see if it works then.
If that doesnt work then try a better graphics card.
RE: Won't Run
Won/t run under 64MB graphics then !
Mind ypu its poor software that can't tell you that when it runs!!
microscopic text on the box
Martin
Martin
MA
RE: Won't Run
http://aeroflypro.com/requirements/
if you look at what they say for cards that they don't recommend the ati all-in-one card is on that list
RE: Won't Run
I ll get one of these, does any one know which will be compatible with my K7S5A motherbord ?
Nvidia GeForce3 and GeForce 4
Nvidia GeForce FX series (5700, 5900)
Nvidia GeForce 6xxx series
Nvidia GeForce 4Go / FX Go / Go 6800
ATI Radeon 9xxx series
ATI Radeon X-series (X700, X-800)
ATI Radeon Mobility 9xxx series
MA
RE: Won't Run
ORIGINAL: martinh
also what's the most you would like to spend on a new video card..keep in mind that buying the cheapest card that will run AFPD doesn't mean that it will run on a high resolution or have high FPS
RE: Won't Run
Went for G Force FX 5200 runs at 60 FPS (Photo Scenery)
Had a problem with IE6 Hanging and rebooting PC
Had to remove and reinstall all my Network Card, ScSI Card, Hollywood DVD in turn to restore sanity.
took nearly 4 hours !!!
Martin
Martin
